[QGIS-trac] Re: [Quantum GIS] #1945: [Vista] Qgis crashes removing GRASS raster layer from map canvas
Quantum GIS qgis at qgis.org
Fri Feb 5 10:43:15 EST 2010
        Reporter:  juanelz                                    |         Owner:  rugginoso
            Type:  bug                                        |        Status:  closed
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.5.0
       Component:  GRASS                                      |       Version:  HEAD
      Resolution:  fixed                                      |      Keywords:  GRASS rasters
Platform_version:  Vista                                      |      Platform:  Windows
        Must_fix:  Yes                                        |   Status_info:  0
Comment (by lutra):
 Hi Radim,
 the first thing I notice is about linux.
 After having compiled trunk, when I open the grass mapset in the qgis demo
 dataset -and then I add the raster that is in there (gtopo30)- qgis (the
 "value tool" plugin to be precise) throws the following
   File "/home/vania/.qgis//python/plugins/valuetool/valuewidget.py", line
 134, in printValue
     self.ymin=min(self.ymin,cstr.minimumValue())
 AttributeError: 'NoneType' object has no attribute 'minimumValue'
 then qgis also throws this
 Cannot query raster
 Cannot start module
 command: /usr/share/qgis/grass/modules/qgis.g.info info=query
 rast=gtopo30 at demo coor=-1.43995e+06,8.38359e+06<br><br>
 GRASS_INFO_WARNING(5191,1): Reading raster map <gtopo30 at demo> request for
 row -174 is outside region
 GRASS_INFO_END(5191,1)
 GRASS_INFO_ERROR(5191,2): Unable to read raster map <gtopo30 at demo> row
 -174
 GRASS_INFO_END(5191,2)
 in both cases when passing the mouse over the raster in the canvas.
 The happens under windows, but not immediately after having added the
 GRASS raster to the canvas. I'll be more precise in the notes that will
 follow this one.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1945#comment:17>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
