[QGIS-trac] Re: [Quantum GIS] #1945: [Vista] Qgis crashes removing
GRASS raster layer from map canvas
Quantum GIS
qgis at qgis.org
Fri Feb 5 13:37:58 EST 2010
#1945: [Vista] Qgis crashes removing GRASS raster layer from map canvas
Reporter: juanelz | Owner: rugginoso
Type: bug | Status: closed
Priority: critical: causes crash or data corruption | Milestone: Version 1.5.0
Component: GRASS | Version: HEAD
Resolution: fixed | Keywords: GRASS rasters
Platform_version: Vista | Platform: Windows
Must_fix: Yes | Status_info: 0
Comment (by lutra):
I'm having an hard time finding a pattern about when the above messages do
show and when not. An interesting finding is that if I create a mapset in
wgs84 and then import some rasters and add them to the canvas then the
messages do not show.
If I create a mapset in the same system of the one available in the qgis
demo mapset (epsg 2964), import the "landcover.img" raster and the add it
to the canvas, then the messages do show always (it happens also using
directly the mapset available in the qgis demo dataset).
I tested to create a mapset in another reference system (epsg 32638)
import a raster with the same projection and add it to the map. It seemed
to me that the messages were showing, but now I can't reproduce... or
maybe I'm just hallucinating (playing with 3 operating systems at one time
is not a good practice for my brain).
Small rasters to do tests can be found here
https://trac.faunalia.it/GdalTools-plugin/wiki
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1945#comment:19>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
