[QGIS-trac] Re: [Quantum GIS] #2369: Cannot change column for
existing graduated (or categorized) symbology
Quantum GIS
qgis at qgis.org
Tue Feb 9 00:40:59 EST 2010
#2369: Cannot change column for existing graduated (or categorized) symbology
Reporter: sowelu | Owner: nobody
Type: enhancement | Status: new
Priority: major: does not work as expected | Milestone: Version 1.5.0
Component: Symbology | Version: HEAD
Resolution: | Keywords:
Platform_version: ubuntu 9.10 | Platform: All
Must_fix: No | Status_info: 0
Comment (by ccrook):
Also found this is a problem. Looks like it was considered in the code
(there are commented out connections signals when the data columns is
changed, though there is no corresponding slot coded that I can see
(qgsgraduatedsymbolrendererv2widget.cpp).
I think that this is a necessary use-case - setting up classification
ranges and symbology can take significant user input and it is reasonable
to want to change the symbology to use a different columns (typically in a
cross-tab type data set, with columns for a number of different,
equivalent items)
Currently workaround is to save the project, edit the column name in the
.qgs project file, and reload.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2369#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
