[QGIS-trac] Re: [Quantum GIS] #2551: SPIT crashes if path to
shapefile contains cyrillic
Quantum GIS
qgis at qgis.org
Fri Jun 18 11:57:52 EDT 2010
#2551: SPIT crashes if path to shapefile contains cyrillic
Reporter: dr | Owner:
Type: bug | Status: closed
Priority: major: does not work as expected | Milestone: Version 1.5.0
Component: C++ Plugins | Version: HEAD
Resolution: wontfix | Keywords:
Platform_version: | Platform: Windows
Must_fix: Yes | Status_info: 0
Changes (by jef):
* priority: critical: causes crash or data corruption => major: does not
work as expected
* status: new => closed
* resolution: => wontfix
Comment:
Replying to [ticket:2551 dr]:
> SPIT crashes if path to shapefile contains cyrillic, for example:
"d:\шейп\".
No crash reproducable here. QGIS refuses to add files in cyrillic
directories on Windows, because {{{OGROpen}}} fails on them. This is a
known GDAL/OGR problem: [[http://trac.osgeo.org/gdal/wiki/rfc5_unicode
rfc5_unicode]].
I suppose this should be fixed in OGR. See also the thread
[[http://lists.osgeo.org/pipermail/qgis-developer/2010-May/009962.html
adding encoding file]] on the developer's mailing list.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2551#comment:5>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
