[QGIS-trac] [Quantum GIS] #2741: (linux) qgis crashes when saving
project with a GRASS raster after having closed the mapset
Quantum GIS
qgis at qgis.org
Fri May 21 16:19:55 EDT 2010
#2741: (linux) qgis crashes when saving project with a GRASS raster after having
closed the mapset
Reporter: lutra | Owner: rblazek
Type: bug | Status: new
Priority: critical: causes crash or data corruption | Milestone: Version 1.5.0
Component: GRASS | Version: HEAD
Keywords: | Platform_version:
Platform: Debian | Must_fix: Yes
Status_info: 0 |
Probably duplicate of #2740
Seen under ubuntu Linux and qgis trunk but not under windows XP
Steps to reproduce:
*) create a mapset (tested with a few projected crs)
*) in the qgis project properties choose the same crs. Not necessary to
enable on the fly reprojection as in #2740
*) add a few GRASS layers, at least one of them a raster
*) if you save the project with the mapset still open the terminal will
return
Warning: Object::connect: No such signal
QgsRasterDataProvider::statusChanged( QString ) in
/home/gio/qgis_unstable/src/core/raster/qgsrasterlayer.cpp:228
*) if before saving you close the GRASS mapset, then qgis will crash with
GDAL Error 6: No translation an empty SRS to PROJ.4 format is
known.
Segmentation fault
*) if you then try to reopen the project it will fail with
Project file read error: unexpected end of file at line 1 column 1 for
file /home/gio/Desktop/teste4.qgs
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2741>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
