[QGIS-trac] Re: [Quantum GIS] #2596: One draw too much on switch off
Quantum GIS
qgis at qgis.org
Sun Nov 14 04:51:43 EST 2010
Reporter: aperi2007 | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.7.0
Component: MapCanvas | Version: Trunk
Keywords: | Platform_version:
Platform: All | Must_fix: No
Status_info: 1 |
Changes (by lutra):
* platform_version: 7 =>
* platform: Windows => All
* milestone: Version 1.6.0 => Version 1.7.0
Comment:
I'm able to see what Andrea is saying.
*) With render caching enabled, then the "number of features to be drawn
before updating the display" does not work anymore. If you refresh the map
the vector will be rendered as if the option is set to "0", so I guess
that it would be needed to disabled this option when the render caching is
enabled.
*) With the render caching is disabled and you choose something different
from "0" in "number of features to be drawn before updating the display"
(and you are using a vector with many features, I'm testing myself a 50000
polygons vector) then the problem is evident.
Add another (small) vector and then start enabling/disabling it in the
TOC, the big vector is continuously redrawn at each click... very
annoying.
In general without render caching enabled (and "number of features to be
drawn before updating the display" set to 0), enabling/disabling a vector
in a project where there are many others vectors, or a few big ones, it
takes really a lot.
I'm on trunk/ubuntu 10,04 and with the render caching enabled, on the
contrary, it works really smooth.
It the options enabled by default?
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2596#comment:4>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
