[QGIS-trac] Re: [Quantum GIS] #3099: Projection Failure
Quantum GIS qgis at qgis.org
Sat Oct 9 05:41:36 EDT 2010
   Reporter:  badams                            |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.6.0
  Component:  Projection Support                |            Version:
   Keywords:  Projection Failure                |   Platform_version:
   Platform:  Windows                           |           Must_fix:  No
Status_info:  0                                 |
Comment(by badams):
 Sorry Lutra, I actually have no idea what your talking about. I'm way out
 of my depth here.
 The test is simple. The CSV file contains the same grid, listed in 4
 different datums, UTM: AGD66, AGD84, GDA94 and WGS84(see projection
 information above).  The projections already exist in QGIS, you don't need
 to change anything. Forget about the srs.db and gsb files for the moment.
 If it worked properly, all 4 datums would plot in the same place.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3099#comment:7>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
