[QGIS-trac] Re: [Quantum GIS] #3099: Projection Failure
Quantum GIS qgis at qgis.org
Sat Oct 9 06:55:01 EDT 2010
   Reporter:  badams                            |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.6.0
  Component:  Projection Support                |            Version:
   Keywords:  Projection Failure                |   Platform_version:
   Platform:  Windows                           |           Must_fix:  No
Status_info:  0                                 |
Comment(by lutra):
 >  The projections already exist in QGIS, you don't need to change
 anything. Forget about the srs.db and gsb files for the moment.
 > If it worked properly, all 4 datums would plot in the same place.
 The "re-projection" already exist in QGIS, right, but without
 transformation parameters such towgs84 or nadgrids, not all datum
 transformations will give good results. This is why in such situations you
 must use towgs84 or nadgrids parameters. Proj4 coordinate system
 definitions come *without* such parameters, so you need to add them
 manually.
 Can you please specify, in terms of EPSG codes, what are the coordinate
 systems of the point grids in the csv file (beside obviously wgs84 that
 has the 4326 code)? thanks
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3099#comment:8>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
