[QGIS-trac] Re: [Quantum GIS] #2913: add support for ntv2 grids and
+towgs84
parameters in the "save as..." dialogs (was: add a "SOURCE SRS"
option in the "save as..." and "save selection as..." dialogs)
Quantum GIS
qgis at qgis.org
Sat Oct 16 06:05:13 EDT 2010
#2913: add support for ntv2 grids and +towgs84 parameters in the "save as..."
dialogs
Reporter: lutra | Owner: nobody
Type: enhancement | Status: new
Priority: major: does not work as expected | Milestone: Version 1.6.0
Component: Data Provider | Version: Trunk
Keywords: | Platform_version:
Platform: All | Must_fix: Yes
Status_info: 0 |
Comment(by lutra):
Follow up description, more resumed and clear (I hope):[[BR]]
[[BR]]
I would like to resume better what would be needed to add the support for
transformations with ntv2 grids and/or +towsgs84 parameters
[[BR]]
[[BR]]
a) a new menu to allow a user import ntv2 grids (.gsb files): the same
files need to be copied in the proper system location, for example
"/etc/proj" for linux
[[BR]][[BR]]
b) add a "source srs" field in the "save as..." and "save selected as..."
dialogs
[[BR]][[BR]]
c) in the same dialog add a dropdown to let the user choose the
appropriate ntv2 grid, among the ones available in the proper system
folder
[[BR]][[BR]]
d) if the user chooses a ntv2 grid the underlying ogr2ogr operation MUST
always add the "+wktext" parameter in the source srs definition
[[BR]][[BR]]
e) if the user chooses a ntv2 grid the underlying ogr2ogr operation MUST
always add the "+towgs84=0,0,0" parameter in the target srs definition, if
this srs is a projected one
[[BR]][[BR]]
f) a field to let the user write manually +towgs84 parameters in case
he/she don't want/need to use ntv2 grids. This field and the ntv2 dropdown
need to be mutually exclusive.
[[BR]][[BR]]
g) add a windows, like the one that shows in the gdal tools, and show the
ogr2ogr command as it is forming while the users chooses the parameters,
and make this command editable, like it was already asked for the gdal
tools.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2913#comment:3>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
