[QGIS-trac] Re: [Quantum GIS] #2987: Auto GCP detection library
Quantum GIS qgis at qgis.org
Mon Oct 18 05:21:42 EDT 2010
   Reporter:  jamesm6162        |              Owner:  timlinux
       Type:  patch             |             Status:  assigned
   Priority:  minor: annoyance  |          Milestone:  Version 1.6.0
  Component:  C++ Plugins       |            Version:  Trunk
   Keywords:                    |   Platform_version:
   Platform:  Debian            |           Must_fix:  No
Status_info:  0                 |
Comment(by timlinux):
 Replying to [comment:12 jamesm6162]:
 > Hi Tim
 > Thanks for the feedback. We are working on getting all the crashes fixed
 adn we'll get to all your recommended features as soon as possible.
 > One question from my side though.
 > What would be the best resource to start looking at if we want to
 implement the Georeferencing with GDAL?
 > Thanks
 > James
 Using gdal_translate either via the python api (I've never tried so you
 will need to check their docs) or by doing a shell call from python. Below
 is an example from some code of mine:
 myString = "gdal_translate -a_srs 'EPSG:4326' -gcp 0 0 %s %s -gcp %s 0 %s
 %s -gcp %s %s %s %s -gcp 0 %s %s %s -of GTIFF -co COMPRESS=DEFLATE -co
 TILED=YES %s %s" % ( \
          myTL[0], myTL[1], \
          myImageXDim, myTR[0],myTR[1], \
          myImageXDim, myImageYDim, myBR[0],myBR[1], \
          myImageYDim, myBL[0],myBL[1], \
          myPath, \
          myOutputPath )
    print myString
    os.system( myString )
 You can add as many -gcp parameters as you like. My example above simply
 georeferences the corners hence the hard coded 0's. You can verify your
 GCPs in the output file by calling gdaoinfo on it.
 Hope that helps!
 Regards
 Tim
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2987#comment:15>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
