[QGIS-trac] [Quantum GIS] #3650: shapefiles fails to be imported
into GRASS
mapset with qgis 1.6/trunk under Windows (but import is fine under
qgis 1.5)
Quantum GIS
qgis at qgis.org
Sun Mar 20 16:52:59 EDT 2011
#3650: shapefiles fails to be imported into GRASS mapset with qgis 1.6/trunk under
Windows (but import is fine under qgis 1.5)
Reporter: lutra | Owner: rblazek
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.7.0
Component: GRASS | Version: 1.6.0
Keywords: | Platform_version:
Platform: Windows | Must_fix: Yes
Status_info: 0 |
I found a few shapefiles (I'll attach one as exemple) that are not
imported into a GRASS mapset under Windows using qgis 1.6/trunk. Using
qgis 1.5 the process runs smoothly.
The output window message under QGIS 1.5 says
v.in.ogr -o dsn=C:/Users/gio/Desktop/GRASS/regioes/regioes.shp output=reg
Datum not recognised by GRASS and no parameters found
Over-riding projection check
Layer: regioes
Importing map 109 features...
Building topology for vector map ...
Registering primitives...
111 primitives registered
19480 vertices registered
Building areas...
109 areas built
109 isles built
Attaching islands...
Attaching centroids...
Number of nodes: 110
Number of primitives: 111
Number of points: 0
Number of lines: 0
Number of boundaries: 111
Number of centroids: 0
Number of areas: 109
Number of isles: 109
Number of incorrect boundaries: 2
Number of areas without centroid: 109
Cleaning polygons, result is not guaranteed!
Number of points: 0
Number of lines: 0
Number of areas: -
Number of isles: -
Break polygons:
Remove duplicates:
Break boundaries:
Remove duplicates:
Clean boundaries at nodes:
Change dangles to lines:
Remove bridges:
Building areas...
110 areas built
91 isles built
Number of nodes: 134
Number of primitives: 211
Number of points: 0
Number of lines: 0
Number of boundaries: 211
Number of areas: 110
Number of isles: 91
Number of areas without centroid: 110
Layer: regioes
262 primitives registered
14879 vertices registered
Building areas...
110 areas built
91 isles built
Number of nodes: 243
Number of primitives: 262
Number of points: 0
Number of lines: 0
Number of boundaries: 153
Number of centroids: 109
Number of isles: 91
109 input polygons
Total area: 3.023812e+011 (110 areas)
Overlapping area: 0.000000e+000 (0 areas)
Area without category: 6.103451e+005 (1 areas)
Successfully finished
The output window message under QGIS 1.6 (standalone) says
v.in.ogr -o dsn=C:/Users/gio/Desktop/GRASS/regioes/regioes.shp output=reg2
Layer: regioes
Building areas...
109 areas built
109 isles built
Number of points: 0
Number of lines: 0
Size of 'coor' file differs from value saved in topology file
Please rebuild topology for vector map
Unable to open topology file for vector map
Finished with error
The output window message under QGIS trunk (osgeo4w) says
snap=-1 min_area=0.0001
Layer: regioes
Default driver / database set to:
driver: dbf
database: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
Building areas...
109 areas built
109 isles built
Number of points: 0
Number of lines: 0
Finished with error
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3650>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
