[QGIS-trac] Re: [Quantum GIS] #3649: Raster calculator does not
assign projection correctly to output raster
Quantum GIS
qgis at qgis.org
Wed Mar 23 12:14:54 EDT 2011
#3649: Raster calculator does not assign projection correctly to output raster
Reporter: timlinux | Owner: mhugent
Type: bug | Status: new
Priority: critical: causes crash or data corruption | Milestone: Version 1.7.0
Component: Rasters | Version: 1.6.0
Keywords: | Platform_version:
Platform: Debian | Must_fix: No
Status_info: 0 |
Comment(by mhugent):
r15581 implements a solution where the crs is copied from the first layer
involved in the calculation.
It however has two disadvantages:
- If there is a constant expression (e.g. '42'), the result has no CRS
assigned. A solution could be to have a crs button in the dialog (but it
is string freeze now).
- The CRS is passed to GDAL as WKT, and there can be some loss of
information depending on the format. E.g. for GeoTiff, the doc says 'Note
that the GeoTIFF format does not support parametric description of datums,
so TOWGS84 parameters in coordinate systems are lost in GeoTIFF format'.
Let me know if there is a better approach to deal with this.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3649#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
