[QGIS-trac] Re: [Quantum GIS] #3650: shapefiles fails to be imported into GRASS mapset with qgis 1.6/trunk under Windows (but import is fine under qgis 1.5)
Quantum GIS qgis at qgis.org
Sun Mar 27 13:31:32 EDT 2011
   Reporter:  lutra                             |              Owner:  rblazek
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.7.0
  Component:  GRASS                             |            Version:  1.6.0
   Keywords:                                    |   Platform_version:
   Platform:  Windows                           |           Must_fix:  Yes
Status_info:  0                                 |
Comment(by lutra):
 > also here the import by v.in.ogr works.
 it still fail for me with osgeo4w/qgis trunk
 v.in.ogr -o dsn=C:/Users/gio/Downloads/regioes_shp/regioes.shp
 output=regioes_test1 snap=-1 min_area=0.0001
 Datum not recognised by GRASS and no parameters found
 Over-riding projection check
 Layer: regioes
 Importing map 109 features...
 Building topology for vector map ...
 Registering primitives...
 111 primitives registered
 19480 vertices registered
 Building areas...
 109 areas built
 109 isles built
 Attaching islands...
 Attaching centroids...
 Number of nodes: 110
 Number of primitives: 111
 Number of points: 0
 Number of lines: 0
 Number of boundaries: 111
 Number of centroids: 0
 Number of areas: 109
 Number of isles: 109
 Number of incorrect boundaries: 2
 Number of areas without centroid: 109
 Cleaning polygons, result is not guaranteed!
 Size of 'coor' file differs from value saved in topology file
 Please rebuild topology for vector map
 Unable to open topology file for vector map
 Finished with error
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3650#comment:6>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
