[QGIS-trac] Re: [Quantum GIS] #3650: shapefiles fails to be imported into GRASS mapset with qgis 1.6/trunk under Windows (but import is fine under qgis 1.5)
Quantum GIS qgis at qgis.org
Mon Mar 28 17:20:31 EDT 2011
   Reporter:  lutra                             |              Owner:  rblazek
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.7.0
  Component:  GRASS                             |            Version:  1.6.0
   Keywords:                                    |   Platform_version:
   Platform:  Windows                           |           Must_fix:  Yes
Status_info:  0                                 |
Comment(by lutra):
 I played around a bit more: the attached vector is always imported with no
 problems if I use the qgis/GRASS shell or if I launch the v.in.ogr GRASS
 GUI from the qgis/GRASS shell.
 If I use the v.in.ogr qgis GUI I still hit the above problems (even not
 using snap=-1 and min_area=0.0001). Funny thing is that if I keep trying
 (actually I have to change the output map name, because of #3646 vectors
 cannot be deleted, then not even overwritten) at the 2nd/3rd try it
 doesn't stop at
 Cleaning polygons, result is not guaranteed!
 Size of 'coor' file differs from value saved in topology file
 Please rebuild topology for vector map
 Unable to open topology file for vector map
 Finished with erro
 but this result usually in a freeze/crash - as per #3648 - before showing
 the "successfully finished" message (but the process has finished, see
 https://trac.osgeo.org/qgis/ticket/3648#comment:6 ).
 I attach another vector that show the same "symptoms".
 I'll appreciate if someone other than me and hellik can give it a try.
 I'm using QGIS trunk/osgeo4w under Seven 32/64 bit.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3650#comment:7>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
