[QGIS-trac] Re: [Quantum GIS] #3648: Qgis 1.6/trunk,
osgeo4w/standalone crashes when importing vectors in a GRASS mapset
or when adding them to the project
Quantum GIS
qgis at qgis.org
Sun Mar 27 13:59:51 EDT 2011
#3648: Qgis 1.6/trunk, osgeo4w/standalone crashes when importing vectors in a
GRASS mapset or when adding them to the project
Reporter: lutra | Owner: rblazek
Type: bug | Status: new
Priority: critical: causes crash or data corruption | Milestone: Version 1.7.0
Component: GRASS | Version: 1.6.0
Keywords: | Platform_version:
Platform: Windows | Must_fix: Yes
Status_info: 0 |
Comment(by hellik):
tested with osgeo4w-qgis-trunk (1.7.0-100) and the attached shapefile.
> *) importing a vector (shapefile) with v.in.ogr
I've imported freguesias.shp several times by v.in.ogr in the same qgis-
grass-session and several times in different qgis-grass-sessions. the
import worked all the time without any qgis-crash. the only thing is that
I thought the first time that the import has already finished (just too
impatient ;-)), but it wasn't.
> *) adding an imported vector by clicking "view output" or using the
proper button in the GRASS (toolbox) toolbar or using the QGIS GRASS
toolbar
tried this in several qgis-grass-sessions, adding the vector sometimes but
not always crashes in an unreproducable way (maybe some memory issues?)
> *) sometimes adding a vector qgis does not crash, but adding a second
time it does
confirmed.
> *) it seems to happen more with lines and polygons than with points and
with vectors that are "big" (I'll attach a 13mb shapefile, in epsg 3003,
that can be used to replicate easily the crashes).
> All it seems pretty unpredictable and it does NOT happens under qgis 1.5
standalone, like #3646
if the attribute table is opened, by scrolling in the attribute entries,
sometimes the attribute table freezes for a very short time
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3648#comment:5>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
