[QGIS-trac] Re: [Quantum GIS] #3648: Qgis 1.6/trunk, osgeo4w/standalone crashes when importing vectors in a GRASS mapset or when adding them to the project
Quantum GIS qgis at qgis.org
Mon Mar 28 04:49:04 EDT 2011
   Reporter:  lutra                                      |              Owner:  rblazek
       Type:  bug                                        |             Status:  new
   Priority:  critical: causes crash or data corruption  |          Milestone:  Version 1.7.0
  Component:  GRASS                                      |            Version:  1.6.0
   Keywords:                                             |   Platform_version:
   Platform:  Windows                                    |           Must_fix:  Yes
Status_info:  0                                          |
Comment(by lutra):
 > I've imported freguesias.shp several times by v.in.ogr in the same qgis-
 grass-session and several times in different qgis-grass-sessions. the
 import worked all the time without any qgis-crash. the only thing is that
 I thought the first time that the import has already finished (just too
 impatient ;-)), but it wasn't.
 really weird. I have also updated qgis-trunk to 1.7.0-100 and now it seems
 that this problem become really rare. I can also import now the attached
 vector over and over almost without any problem. I got a crash but it was
 one among tens of attempts...
 > > *) adding an imported vector by clicking "view output" or using the
 proper button in the GRASS (toolbox) toolbar or using the QGIS GRASS
 toolbar
 > tried this in several qgis-grass-sessions, adding the vector sometimes
 but not always crashes in an unreproducable way (maybe some memory
 issues?)
 as above, now it works almost without problems. Crashes doing this
 operation become rare. More common when adding more then one vector at the
 same time
 > > *) sometimes adding a vector qgis does not crash, but adding a second
 time it does
 > confirmed.
 see above.
 > > *) it seems to happen more with lines and polygons than with points
 and with vectors that are "big" (I'll attach a 13mb shapefile, in epsg
 3003, that can be used to replicate easily the crashes).
 > > All it seems pretty unpredictable and it does NOT happens under qgis
 1.5 standalone, like #3646
 after the first tests it become clear that there is (was?) no pattern.
 > if the attribute table is opened, by scrolling in the attribute entries,
 sometimes the attribute table freezes for a very short time
 yes, VERY slow to scroll the attributes table. I don't see "short time
 freezes", if the table has just hundreds of records it freezes for many
 seconds.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3648#comment:6>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
