[QGIS-trac] Re: [Quantum GIS] #3648: Qgis 1.6/trunk, osgeo4w/standalone crashes when importing vectors in a GRASS mapset or when adding them to the project
Quantum GIS qgis at qgis.org
Mon Mar 28 17:29:52 EDT 2011
   Reporter:  lutra                                      |              Owner:  rblazek
       Type:  bug                                        |             Status:  new
   Priority:  critical: causes crash or data corruption  |          Milestone:  Version 1.7.0
  Component:  GRASS                                      |            Version:  1.6.0
   Keywords:                                             |   Platform_version:
   Platform:  Windows                                    |           Must_fix:  Yes
Status_info:  0                                          |
Comment(by lutra):
 it is really unpredictable. Sometimes seems to work overall in a
 acceptable way, other times is very unstable/fragile and freezes crashes
 when importing/adding/removing (from qgis TOC) a vector that seemed to
 work fine minutes before. You may also want to try the vectors attached to
 #3650 and/or merge the two tickets, they seems related to me.
 I'll appreciate if someone other than me and hellik can give it a try.
 I'm using QGIS trunk/osgeo4w under Seven 32/64 bit.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3648#comment:8>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
