[QGIS-trac] Re: [Quantum GIS] #3766: (windows): on trunk/osgeo4w
adding a GRASS
raster causes qgis to crash (was: (windows): on trunk/osgeo4w
adding a GRASS raster causes qgis.g.info.exe to crash)
Quantum GIS
qgis at qgis.org
Sun May 1 05:36:55 EDT 2011
#3766: (windows): on trunk/osgeo4w adding a GRASS raster causes qgis to crash
Reporter: lutra | Owner: rblazek
Type: bug | Status: reopened
Priority: critical: causes crash or data corruption | Milestone: Version 1.7.0
Component: GRASS | Version: Trunk
Resolution: | Keywords:
Platform_version: | Platform: Windows
Must_fix: No | Status_info: 0
Changes (by lutra):
* priority: major: does not work as expected => critical: causes crash
or data corruption
* status: closed => reopened
* resolution: fixed =>
Comment:
testing r15861 (package 128). Now when adding a raster map the following
warning shows 3 times and then qgis crashes
Cannot get projection
Cannot run module
command: C:/OSGeo4W/apps/qgis-dev/./grass/modules/qgis.g.info
info=proj<br><br>ERROR: Incompatible library version for module. You need
to rebuild GRASS
or untangle multiple installations.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3766#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS supporting GDAL/OGR, PostGIS, and GRASS formats, and Web Services
More information about the QGIS-trac
