[QGIS-trac] Re: [Quantum GIS] #3430: fill pattern missing for point markers in new symbology engine
Quantum GIS qgis at qgis.org
Sun May 1 06:22:24 EDT 2011
   Reporter:  nirvn                             |              Owner:  sunilkcube
       Type:  patch                             |             Status:  assigned
   Priority:  major: does not work as expected  |          Milestone:  Version 1.7.0
  Component:  Symbology                         |            Version:  Trunk
   Keywords:                                    |   Platform_version:
   Platform:  All                               |           Must_fix:  No
Status_info:  0                                 |
Comment(by Alister):
 I find that I can switch a layer from old symbology to new symbology
 successfully, but not back again.  The patch could be improved slightly by
 allowing it to switch back, but I think this is a very minor issue
 (probably not worth the effort to fix) if old symbology is to be removed
 from QGIS soon.
 e.g.
 - select the first point symbol (circle) in old symbology, set the fill
 options to "None", Apply
 - switch to new symbology and Apply - the markers should stay the same
 (apart from outline width, which is #3458)
 - switch to old symbology - the markers will now have a solid fill
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3430#comment:7>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS supporting GDAL/OGR, PostGIS, and GRASS formats, and Web Services
More information about the QGIS-trac mailing list
