[Qgis-us-user] Photos Import
    Kurt Menke
    kurt at birdseyeviewgis.com
    Wed Apr  8 13:13:49 PDT 2020
Hi David,
Randy's advice is spot on. Instead of using eVis, you can set up an image
widget (Layer Properties --> Attributes form) for the field containing the
path to the image and then see the image when you use the Identify tool.
But it needs to point to an actual image file to do this.
If the photos are geotagged you can use the Import geotagged photos
processing algorithm. You can then use the Raster image marker to put the
photos on a map. I have an exercise in my Discover QGIS 3.x book that
focuses on mapping photopoints.
See this tweet: https://twitter.com/geomenke/status/1221470553040539648?s=20
Kurt
Kurt Menke
Bird’s Eye View
QGIS Certified Trainer
3016 Santa Clara Ave SE
Albuquerque, NM 87106
www.BirdsEyeViewGIS.com <http://www.birdseyeviewgis.com/>
Cell: 505-362-1776
Work: 505-265-0243
Fax: 505-265-0243
QCooperative
https://www.qcooperative.net/
Blogger @Community Health Maps
https://www.communityhealthmaps.org/
URL: <http://lists.osgeo.org/pipermail/qgis-us-user/attachments/20200408/9fb9d47d/attachment.html>
More information about the Qgis-us-user
