[Qgis-us-user] Photos Import
    Kurt Menke
    kurt at birdseyeviewgis.com
    Wed Apr  8 13:19:21 PDT 2020
Absolutely.
You could then filter the photos by date, make a series of maps by date
using the Atlas, or even animate it with the Time Manager plugin.
Kurt
On Wed, Apr 8, 2020 at 2:17 PM Doug Newcomb <gistinker at gmail.com> wrote:
> If you have multiple images of a location over time, could they be
> imported into a geopackage database and be accessed to display with the
> location based on the timestamp?
> On Wed, Apr 8, 2020, 4:14 PM Kurt Menke <kurt at birdseyeviewgis.com> wrote:
>> Hi David,
>> Randy's advice is spot on. Instead of using eVis, you can set up an image
>> widget (Layer Properties --> Attributes form) for the field containing the
>> path to the image and then see the image when you use the Identify tool.
>> But it needs to point to an actual image file to do this.
>> If the photos are geotagged you can use the Import geotagged photos
>> processing algorithm. You can then use the Raster image marker to put the
>> photos on a map. I have an exercise in my Discover QGIS 3.x book that
>> focuses on mapping photopoints.
>> See this tweet:
>> https://twitter.com/geomenke/status/1221470553040539648?s=20
>> Kurt
>> Kurt Menke
>> Bird’s Eye View
>> QGIS Certified Trainer
>> 3016 Santa Clara Ave SE
>> Albuquerque, NM 87106
>> www.BirdsEyeViewGIS.com <http://www.birdseyeviewgis.com/>
>> Cell: 505-362-1776
>> Work: 505-265-0243
>> Fax: 505-265-0243
>> QCooperative
>> https://www.qcooperative.net/
>> Blogger @Community Health Maps
>> https://www.communityhealthmaps.org/
>> Qgis-us-user mailing list
>> Qgis-us-user at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/qgis-us-user
Kurt Menke
Bird’s Eye View
Cell: 505-362-1776
Work: 505-265-0243
Fax: 505-265-0243
QCooperative
Author:
https://locatepress.com/hyd
*https://locatepress.com/dq3 <https://locatepress.com/dq3> *
URL: <http://lists.osgeo.org/pipermail/qgis-us-user/attachments/20200408/460ee2b2/attachment.html>
More information about the Qgis-us-user
