[Qgis-us-user] Photos Import
David Knox
david.knox at comba.org
Wed Apr 8 13:35:54 PDT 2020
Thanks everyone! I'll give it a try. Appreciate your patience with a
newbie. I'll order the book too....
david
On Wed, Apr 8, 2020 at 2:14 PM Kurt Menke <kurt at birdseyeviewgis.com> wrote:
> Hi David,
> Randy's advice is spot on. Instead of using eVis, you can set up an image
> widget (Layer Properties --> Attributes form) for the field containing the
> path to the image and then see the image when you use the Identify tool.
> But it needs to point to an actual image file to do this.
> If the photos are geotagged you can use the Import geotagged photos
> processing algorithm. You can then use the Raster image marker to put the
> photos on a map. I have an exercise in my Discover QGIS 3.x book that
> focuses on mapping photopoints.
> See this tweet:
> https://twitter.com/geomenke/status/1221470553040539648?s=20
> Kurt
> Kurt Menke
> Bird’s Eye View
> QGIS Certified Trainer
> 3016 Santa Clara Ave SE
> Albuquerque, NM 87106
> www.BirdsEyeViewGIS.com <http://www.birdseyeviewgis.com/>
> Cell: 505-362-1776
> Work: 505-265-0243
> Fax: 505-265-0243
> QCooperative
> https://www.qcooperative.net/
> Blogger @Community Health Maps
> https://www.communityhealthmaps.org/
> Qgis-us-user mailing list
> Qgis-us-user at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-us-user
Deputy Trails Lead
Mobile/Text 303-748-8906
URL: <http://lists.osgeo.org/pipermail/qgis-us-user/attachments/20200408/64518472/attachment-0001.html>
More information about the Qgis-us-user
