AW: [Qgis-user] why is EPSG:2180 not recognised?
Richard Duivenvoorde rdmailings at duif.net
Mon Apr 7 11:49:27 PDT 2008
I've got sqliteadmin (http://sqliteadmin.orbmu2k.de/) here, and it seems
pretty trivial to update the database srs.db with that tool...
Though it might not be that trivial?
Looking at a freshly downloaded epsg file of the proj lib, I see
	# WGS 72
	<4322> +proj=longlat +ellps=WGS72 +no_defs  <>
The same holds true for 4322, 4622 and 4625
Can somebody explain to me then why it should be jean-claude's version?
Or in other words, if the latest proj doesn't have it, what/who should
be the authorative source in this case then?
The srs.db. is nothing more then the parameters used by proj isn't it?
Or am I missing something here?
3328 - 3335 are indeed available in latest proj (and not in srs.db), so
it should be easy to add them.
same for 3120
same for 3066
If I can count on some help with projection-specific questions, I can
make it a part of my 'release-team' work? I will add it to the
release-checklist in wiki then.
Is it ok to update it for every release, or for every 'bug' people find
in it?
Regards,
Hugentobler Marco wrote:
> Hi Maciej, Jean-Claude
>> Please don't tell me that I can send a patch with updates for the CS
>> database. That would fix only my problem, while EPSG database has lots
>> of fixes and additions in each new version, which get included in new
>> releases of PROJ, GDAL, GRASS but not in QGIS.
> It is of course also possible that you update the other entries in the sqlite database of qgis.
> Ideal would be a volunteer that acts as a maintainer of srs.db and updates it in regular periods.
> Regards,
> Marco
> -----Ursprüngliche Nachricht-----
> Von: qgis-user-bounces at lists.osgeo.org im Auftrag von Jean-Claude Repetto
> Gesendet: Mo 07.04.2008 10:09
> An: qgis-user at lists.osgeo.org
> Betreff: Re: [Qgis-user] why is EPSG:2180 not recognised?
> Maciej Sieczka wrote :
>> QGIS CS database is severly outdated.
> Hello,
> I agree.
> Other examples :
> WGS72 (EPSG 4322)
> The QGIS database contains :
> It should be :
> +proj=longlat +ellps=WGS72 +towgs84=0,0,4.5,0,0,0.554,0.219 +no_defs
> (look at <http://proj.maptools.org/gen_parms.html#towgs84>)
> Guadeloupe 1948 (EPSG 4622)
> +proj=longlat +ellps=intl +no_defs
> It should be :
> +towgs84=-472.29,-5.63,-304.12,0.4362,-0.8374,0.2563,1.8984 +no_defs
> Martinique 1938 (EPSG 4625)
> +proj=longlat +ellps=intl +no_defs  <>
> It should be :
> +towgs84=126.93,547.94,130.41,-2.7867,5.1612,-0.8584,13.8227 +no_defs
> Conclusion : Don't trust the EPSG database, allways check the parameters.
> Jean-Claude
> Qgis-user mailing list
