AW: [Qgis-user] why is EPSG:2180 not recognised?
Jean-Claude Repetto
jcrml at mxm.eu
Tue Apr 8 01:10:35 PDT 2008
Richard Duivenvoorde wrote :
> Looking at a freshly downloaded epsg file of the proj lib, I see
> # WGS 72
> <4322> +proj=longlat +ellps=WGS72 +no_defs <>
> The same holds true for 4322, 4622 and 4625
> Can somebody explain to me then why it should be jean-claude's version?
> Or in other words, if the latest proj doesn't have it, what/who should
> be the authorative source in this case then?
> The srs.db. is nothing more then the parameters used by proj isn't it?
> Or am I missing something here?
You can't rely on the epsg file of the PROJ.4 project. Lots of
parameters are wrong. This is due to a limitation of the automated
translator that converts the EPSG database to the PROJ.4 epsg file.
Please read this thread on the PROJ.4 ML :
<http://www.nabble.com/epsg-parameters-td16447986.html>
This is Frank Warmerdam's answer :
> The problem is that if EPSG offers more than one transformation to
> WGS84 for a datum, the automated translation gives up and offers none
> of them preferring for the user to make the decision themselves.
I think it would be better to create the srs.db database directly from
the EPSG database.
Regards,
Jean-Claude
