AW: [Qgis-developer] Re: [Qgis-user] EPSG:2180 not recognised, although present in srs.db
Hugentobler Marco marco.hugentobler at karto.baug.ethz.ch
Tue Apr 8 06:42:17 PDT 2008
I also tried the example tif with the latest svn trunk (r8327) and QGIS seems to detect epsg 2180 correctly.
Maybe it depends on versions of gdal/proj4? The versions I use are proj 4.5 .0 and gdal 1.4.0
Regards,
Marco
-----Ursprüngliche Nachricht-----
Von: qgis-developer-bounces at lists.osgeo.org im Auftrag von Maciej Sieczka
Gesendet: Di 08.04.2008 14:50
An: Craig Leat
Cc: qgis-user at lists.osgeo.org; qgis-developer at lists.osgeo.org
Betreff: [Qgis-developer] Re: [Qgis-user] EPSG:2180 not recognised,although present in srs.db
Craig Leat pisze:
> Maciej Sieczka wrote:
>> The main point of my email was that although QGIS *has* EPSG 2180 in
>> it's CS database, it fails to recognize this georeference in a
>> GeoTIFF. Looks like a bug, doesn't it?
>> Try the attached GeotTIFF:
> I tested your sample GeoTiff with EPSG:2180 and 0.9.1 branch of QGIS and
> find no errors.
Hi Craig
What do you mean by "no errors"?
In Settings > Options > Projection set "Prompt for projection". Load the
GeoTIFF. Does QGIS recognize it's CS at load? For me it doesn't (trunk
r8319 on Debian testing).
Maciek
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
