[Qgis-user] EPSG:2180 not recognised, although present in srs.db
Goyo
goyodiaz at gmail.com
Tue Apr 8 12:11:26 PDT 2008
Hi Maciej,
I loaded your file in a new project and the detected projection is:
ETRS89 / Poland CS92
QGIS SRID: 181
PosGIS SRID: 2180
Using 0.9.2x1 from Tim's Launchpad repository and gdal 1.4.2-3 from
UbuntuGIS in Ubuntu Gutsy.
Goyo
El mar, 08-04-2008 a las 12:46 +0200, Maciej Sieczka escribió:
> Hugentobler Marco pisze:
> > It is of course also possible that you update the other entries in
> > the sqlite database of qgis.
> The outdated srs.db is only one thing, mentioned BTW the main issue. It
> should be discussd separately. Sorry for mixing it in.
> The main point of my email was that although QGIS *has* EPSG 2180 in
> it's CS database, it fails to recognize this georeference in a GeoTIFF.
> Looks like a bug, doesn't it?
> Try the attached GeotTIFF:
> It's in EPSG:2180. QGIS has EPSG:2180 in it's database. The georefernce
> in the GeoTIFF's header is 100% OK. It was created with "gdalwarp -t_srs
> EPSG:2180". Yet QGIS insists it can't recognize the georeference.
> However, QGIS does recognize "more generic" georeference in GeoTIFFs,
> like EPSG:4326 (ll/WGS84), EPSG:32633-32635 (UTM 33N-35N), EPSG:4179
> (ll/Krassovsky). Why does it fail on 2180 though?
> Maciek
> Qgis-user mailing list
