[Qgis-user] How to delete a ring?
Marco Hugentobler marco.hugentobler at karto.baug.ethz.ch
Tue Apr 15 22:44:29 PDT 2008
Hi Carlos,
It is not (yet) possible to delete rings. At the moment, QGIS does not delete
vertices from rings if there are only three of them (to avoid geos
exceptions). However, it doesn't consider that there may be rings that
already have less than three points (that's the reason for the crash I
think).
I created two tickets for this on track, one for the crash and another one for
the possibility to delete rings.
Regards,
Marco
Am Montag 14 April 2008 18:50:42 schrieb Carlos Dávila:
> I have a layer with some rings in it. I want to remove those rings to
> have just the outer polygon. I can delete ring vertex one by one, but
> when there's only three left I can't continue. If I try to delete
> remaining vertex nothing happens or qgis crashes. I attach the layer.
> Regards
> Carlos
Dr. Marco Hugentobler
Institute of Cartography
ETH Zurich
Technical Advisor QGIS Project Steering Committee
