[Qgis-user] installing on Ubuntu
Chris H
chris123 at magma.ca
Thu Apr 24 04:48:27 PDT 2008
On Thursday 24 April 2008 03:46:40 Jürgen E. Fischer wrote:
>What did you try exactly and what was the error message?
OK...let me try that as the original install was as follows:
libqgis1_0.9.2x1_i386.deb
which required gdal
then
libqgis-core0.10_0.10.0-3_i386.deb which results in the incompatibility.
Leaving libqgis out seemed to do the trick. However the program does not start
with the following packages installed:
libqgis-gui0.10_0.10.0-3_i386.deb
So looking at the packages contents does not reveal an executable ie: qgis
The packages available via launchpad are the following
libqgis1_0.9.2x1_i386.deb libqgis-gui0.10_0.10.0-3_i386.deb
libqgis-core0.10_0.10.0-3_i386.deb qgis-plugin-grass_0.10.0-3_i386.deb
libqgisgrass0.10_0.10.0-3_i386.deb
I did not install the grass packages as I have no need for them at present.
Any guidance..:)??
Thanks
/ch
