[Qgis-user] how to export mapfile in qgis?
John C. Tull john.tull at wildnevada.org
Fri Apr 25 08:48:18 PDT 2008
You might try to use the non-python version of the Mapserver export
plugin. Gary ported from C++ to python, but I have had problems also
with the python module, but on OS X. Try removing the plugin with the
plugin manager, then deleting the actual plugin from your python
plugin directory. I do not know where that directory exists on
Windows, so maybe someone else can chime in on that. Afterwards, the
0.1 version of the plugin should be available in the Plugin Manager
dialog. That is the C++ version.
John
On Apr 25, 2008, at 2:33 AM, Chen kuja wrote:
> hi all,
>        I just installed the qgis 0.92. But when I try to export
> mapfile,  a dialogue box  popped  up("An error has occured while
> executing Python code:"). I've installed the python1.5.2 before
> installing qgis. Also, I chose c:\qgis as Qgis's folder. But stil,
> same  error message like
> Traceback (most recent call last):
>  File "C:/qgis/./python/plugins\mapserver_export
> \mapserverexport.py", line 81, in run
>   exporter = Qgis2Map(self.dlg.ui.txtQgisFilePath.text(),
> self.dlg.ui.txtMapFilePath.text())
>  File "C:/qgis/./python/plugins\mapserver_export\ms_export.py", line
> 37, in __init__
>   self.qgs = minidom.parse(projectFile)
>  File "C:\Python25\Lib\xml\dom\minidom.py", line 1913, in parse
>   return expatbuilder.parse(file)
>  File "C:\Python25\Lib\xml\dom\expatbuilder.py", line 928, in parse
>   result = builder.parseFile(file)
>  File "C:\Python25\Lib\xml\dom\expatbuilder.py", line 204, in
> parseFile
>   buffer = file.read(16*1024)
> AttributeError: read
> My OS is winXp sp2. Besides, same thing happened after I installed
> qgis on my roommate's pc which has nothing to do with any kind of
> gis software.
> I know nothing about python, and I've tried almost everything I
> could find by google. So any helpful information would be
> appreciated. I need this to accomplish my graduating design..so plz..
> ps.
> "C:/qgis/./python/plugins\mapserver_export\mapserverexport.py
> two different kinds of  slash, will it causes the problem?
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20080425/9ecba905/attachment.html>
