[Qgis-user] coordinates in both projected and geographic systems
John C. Tull
john.tull at wildnevada.org
Wed Aug 6 09:14:21 PDT 2008
I see the option to toggle it in the toolbar menu, so that takes care
of that concern.
Nice work,
John
> This is a nice plugin/addition.
> One possible issue I encountered: if you close the coordinate window
> (if floating) or the view in the toolbar, how can you get the window
> or toolbar view back without an application restart? Intuitively,
> hitting the plugin icon or selecting it from the plugin menu should
> do a check to see if the floating window or toolbar/legend view is
> present and reinitiate as required.
> Thanks,
> John
> On Aug 6, 2008, at 7:27 AM, Tim Sutton wrote:
>> Hi
>> I wrote a little plugin that lets you click on the map and copy the
>> coordinates to the clipboard. If you are using on the fly projection
>> it will display coordinates both in lat/lon and in the map canvas
>> projection.
>> http://www.flickr.com/photos/timlinux/2738766800/
>> http://www.flickr.com/photos/timlinux/2738766796/
>> Probably doesnt address all the needs expressed in this thread but
>> hopefully it will take you some way there. Plugin is in SVN trunk and
>> will be in QGIS 1.0.0
>> Regards
>> Tim
>> 2008/8/4 Tim Sutton <tim at linfiniti.com>:
>>> Hi
>>> Both use cases are technically not difficult I think - its just a
>>> matter of someone finding the time amongst all the other things that
>>> need sorting out for QGIS 1.0. Be sure to file a feature /
>>> enhancement
>>> request and we will get to this when time permits.
>>> Regards
>>> Tim
>>> 2008/7/31 Michael Neubauer <Neubauer-Michael at gmx.net>:
>>>> Actually, I was thinking about a similar problem:
>>>> I am working in an area, where two different projections are used
>>>> (UTM and
>>>> S42). So I get locations in both coordinate systems and I would
>>>> like to
>>>> display them at the same time on the map.
>>>> So I have the same wish as Austin, only that I would like to have
>>>> two
>>>> different projected systems displayed.
>>>> Maybe it is already possible...?
>>>> Thank you very much for thinking about it.
>>>> micha
>>>> Am Mittwoch 30 Juli 2008 18:06:31 schrieb Agustin Lobo:
>>>>> Could it be possible in the future having the
>>>>> coordinates displayed both in the projection system
>>>>> of the project (as it is now ) and as geographic
>>>>> (lon, lat) coordinates? For example, today I was
>>>>> using my data in qgis as an aid to search the spot
>>>>> catalogue, where you define windows as lat, lon.
>>>>> Having had both types of coordinates would been
>>>>> helpful.
>>>>> Thanks!
>>>>> Agus
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Tim Sutton
>>> QGIS Project Steering Committee Member - Release Manager
>>> Visit http://qgis.org for a great open source GIS
>>> Blog: http://tim.linfiniti.com
>>> Skype: timlinux
>>> Irc: timlinux on #qgis at freenode.net
>> Tim Sutton
>> Skype: timlinux
