[Qgis-user] coordinates in both projected and geographic systems
Agustin Lobo Agustin.Lobo at ija.csic.es
Wed Aug 6 13:10:58 PDT 2008
Thanks, this is even more than I was asking for, as the user
can copy the coordinates to the clipboard, which is very useful as well.
If this is in svn trunk I understand that this feature will
be in the core of QGIS, not a plugin. If it's a plugin, should not be
installed through the plugin manager?
Agus
Tim Sutton wrote:
> Hi
> I wrote a little plugin that lets you click on the map and copy the
> coordinates to the clipboard. If you are using on the fly projection
> it will display coordinates both in lat/lon and in the map canvas
> projection.
> http://www.flickr.com/photos/timlinux/2738766800/
> http://www.flickr.com/photos/timlinux/2738766796/
> Probably doesnt address all the needs expressed in this thread but
> hopefully it will take you some way there. Plugin is in SVN trunk and
> will be in QGIS 1.0.0
> Regards
> Tim
> 2008/8/4 Tim Sutton <tim at linfiniti.com>:
>> Hi
>> Both use cases are technically not difficult I think - its just a
>> matter of someone finding the time amongst all the other things that
>> need sorting out for QGIS 1.0. Be sure to file a feature / enhancement
>> request and we will get to this when time permits.
>> Regards
>> Tim
>> 2008/7/31 Michael Neubauer <Neubauer-Michael at gmx.net>:
>>> Actually, I was thinking about a similar problem:
>>> I am working in an area, where two different projections are used (UTM and
>>> S42). So I get locations in both coordinate systems and I would like to
>>> display them at the same time on the map.
>>> So I have the same wish as Austin, only that I would like to have two
>>> different projected systems displayed.
>>> Maybe it is already possible...?
>>> Thank you very much for thinking about it.
>>> micha
>>> Am Mittwoch 30 Juli 2008 18:06:31 schrieb Agustin Lobo:
>>>> Could it be possible in the future having the
>>>> coordinates displayed both in the projection system
>>>> of the project (as it is now ) and as geographic
>>>> (lon, lat) coordinates? For example, today I was
>>>> using my data in qgis as an aid to search the spot
>>>> catalogue, where you define windows as lat, lon.
>>>> Having had both types of coordinates would been
>>>> helpful.
>>>> Thanks!
>>>> Agus
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Tim Sutton
>> QGIS Project Steering Committee Member - Release Manager
>> Visit http://qgis.org for a great open source GIS
>> Blog: http://tim.linfiniti.com
>> Skype: timlinux
>> Irc: timlinux on #qgis at freenode.net
Dr. Agustin Lobo
Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
LLuis Sole Sabaris s/n
08028 Barcelona
Spain
Tel. 34 934095410
Fax. 34 934110012
email: Agustin.Lobo at ija.csic.es
http://www.ija.csic.es/gt/obster
