[Qgis-user] how to add a column using the QGIS interface
Alex Mandel
tech_dev at wildintellect.com
Thu Aug 7 16:13:34 PDT 2008
Clara Isabel Bohorquez wrote:
> Hello,
> I am trying to add a new column to a table, but despite the fact I see a "new column" button when I open the attribute table I am not able to use it. It is like the developers will make that option available in a future version of QGIS.
> Can anyone explain to me how to add a column, and then name it and add values to it?
> Thanks a lot,
> Clara
There is one plugin which will add a column, but it generates a new
shapefile. TableManager in Borys repo
http://www.bwj.aster.net.pl/qgis/plugins.xml
You can try to cheat it and use OpenOffice to add a new column. Although
I hear there's a bug in 2.4 that doesn't write dbf files properly.
Alex
