[Qgis-user] editing dbf files
    Werner Macho
    werner.macho at gmail.com
    Mon Aug 11 13:46:04 PDT 2008
Hi Richard,
Probably that doesn't help you at all but the only program I know (And
unfortunately HAVE to use when editing bigger .dbf files than the
mentioned 65536 lines) is the statistical program SPSS.
Very rarely I have to edit such big files too and still found no other
way to comfortably edit those files.
But I'd like to see such capability in QGis too
regards
Werner
On Mo, 2008-08-11 at 18:38 +0200, Richard Duivenvoorde wrote:
> Hi List,
> I've these pretty big .dbf-files (that is more then the 64000something
> you can edit in Excel/Openoffice), without corresponding shp file.
> I was told to edit those in arcview, but off course wanted to do this in
> qgis. But I fail to open/edit them.
> I tried both in metis in xp and ubuntu. I can open the file (as a
> 'raster'), but when I try to look at the 'table', qgis either shows the
> columns, but empty fields of crashes (in ubuntu rasing a warning:
> WARNING: This code (file
> /build/buildd/qgis-0.11.0/src/core/qgsvectorlayer.cpp, line 1068) should
> never be reached. Problems may occur...
> question:
> should qgis be able to edit a stand-alone dbf-file?
> if so, what's the right way to do this/
> if not: I'm aware there are other options to do this ;-)
> Regards,
> Qgis-user mailing list
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20080811/771f6ef2/attachment.sig>
