Fwd: [Qgis-user] GPS Plugin - QGIS 0.11- Mac OSX.5.4
Mars Sjoden
amagine at telus.net
Wed Aug 13 10:57:41 PDT 2008
Thank you Alex,
No, that call does not work. Not sure that the problem is with the
gpsbabel call.
I keep receiving the:
THE LAYER IS NOT A VALID LAYER AND CAN NOT
BE ADDED TO THE MAP
Very curious indeed.
Anyone else able to use the GPS PLUGIN on Mac OSX?
or anyone with related issues?
thanks.
Mars
On 13-Aug-08, at 2:45 AM, Alex Mandel wrote:
>> Mars Sjoden wrote:
>>> Hello Q list,
>>> I am having difficulty getting the GPS Plugin working for
>>> downloading from my Garmin GPSmap 60CSx
>>> I have gpsbabel version 1.3.4 installed and active on my PATH.
>>> (long story but the new v1.3.5 does not work on my iMac)
>>> I am able to use gpsbabel just fine from the command line. ie.
>>> downloads and uploads fine from/to my gps.
>>> I am pretty sure this is not a gpsbabel issue as far as I can tell.
>>> So I launch the GPS Plugin "GPS Tools"
>>> Select "Download from GPS" tab.
>>> Select *Garmin * from the GPS device button list. Port (There are
>>> no choices here from the button list)
>>> Feature type: *Waypoints*
>>> I tried the original setup and receive this output:
>>> *The layer is not a valid layer and can not*
>>> *be added to the map*
>>> I decided to add a gpx layer to QGIS, and name it as the layer for
>>> output. Same output.
>>> I then edited the device to look like, for example waypoint
>>> download:
>>> gpsbabel -w -i garmin -f usb: -o gpx %out
>>> I still receive the same output as above.
>>> I am wondering what I am doing wrong here,
>>> how can I get this working?
>>> I can remember using the gps plugin in 0.8 and it working slick
>>> with out any need for fiddling.
>>> thank you!
>>> mars
>> Here is my usb line (Linux with Garmin 60csx)
>> %babel -i garmin -f usb: -o gpx -F %out
>> I'm to tired to reason out the difference but give it a shot.
>> Alex
