[Qgis-user] QGIS looses toolbar icons after	changing	background	color
    Maciej Sieczka
    tutey at o2.pl
    Mon Aug 18 01:19:02 PDT 2008
Nikos Alexandris pisze:
> Now, while I run QGIS from within GRASS and use GRASS tools without
> problems, I can't even load the GRASS-plugin if I run QGIS outside of
> the GRASS-shell.
Is there a particular reason you start QGIS from within the GRASS shell?
> qgis: symbol lookup error: /usr/local/lib/libqgisgrass.so.1.0:
> undefined
> symbol: G__no_gisinit
Looks like bad linking at the build time. Get rid of all the stuff and
rebuild. If you like try my build scripts - attached (make sure to
adjust them first; there are couple of things hardcoded).
Maciej Sieczka
www.sieczka.org
Type: application/x-sh
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20080818/f562d6a6/attachment.sh>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20080818/f562d6a6/attachment.ksh>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20080818/f562d6a6/attachment-0001.ksh>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20080818/f562d6a6/attachment-0002.ksh>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20080818/f562d6a6/attachment-0003.ksh>
