[Qgis-user] QGIS Windows build fails to load WMS with format image/jpeg
Marco Pasetti
marcopstt at gmail.com
Tue Aug 19 03:12:30 PDT 2008
Hi Tim,
> Hope you had a nice holiday :-)
yes, thanks :-)
> You wouldnt see any problems with dep
> walker sinve qt image support for jpeg is via plugins. Also on your
> dev system you probably wont see an issue since Qt will find the
> plugins in the Qt dir.
oh, yes, what a stupid I am! I forgot to test it renaming the DevTools
folder, as I'm used to!
In fact, I did it, and the WMS loader (after connecting to the server) shows
only the PNG option
> If you check main.cpp under src/app you will
> see the seaerch path used for qt image plugins.
> Copy the image plugins
> from qtdir/plugins/imageformats/* into the qgis dir using the expected
> subdir
Using Process Monitor I noticed the following failings:
C:\DEVTOOLS\QT-OPENSOURCE\PLUGINS\IMAGEFORMATS\QGIF4.DLL
C:\DEVTOOLS\QT-OPENSOURCE\PLUGINS\IMAGEFORMATS\QICO4.DLL
C:\DEVTOOLS\QT-OPENSOURCE\PLUGINS\IMAGEFORMATS\QJPEG4.DLL
C:\DEVTOOLS\QT-OPENSOURCE\PLUGINS\IMAGEFORMATS\QMNG4.DLL
C:\DEVTOOLS\QT-OPENSOURCE\PLUGINS\IMAGEFORMATS\QSVG4.DLL
C:\DEVTOOLS\QT-OPENSOURCE\PLUGINS\IMAGEFORMATS\QTIFF4.DLL
I think I should put them in the qgis/plugins, right?
I opened the cpp file and rapidly read it (I'm very short in times, sorry):
at lines 535-536 I read:
myPath += "/Contents/plugins";
QCoreApplication::addLibraryPath( myPath );
Should I create a qgis/Contents/plugins dir, or the qgis/plugins is enough?
Then, I also found the following "failings" (detected by Process Manager but
not from DepWalker):
C:\DevTools\Qt-OpenSource\bin\wintab32.dll
C:\DevTools\Qt-OpenSource\bin\ssleay32.dll
I do know nothing about wintab32.dll, while ssleay32.dll is the OpenSSL
driver... but either PgSQL nor SQLite have been compiled with the OpenSSL
support
Should I add them though? in the qgis root? at lines 537-539 of the main.cpp
I read as follows:
//next two lines should not be needed, testing only
//QCoreApplication::addLibraryPath( myPath + "/imageformats" );
//QCoreApplication::addLibraryPath( myPath + "/sqldrivers" );
interesting... but not actually compiled! (commented text). suggestions?
Finally: do you prefer a patch or a new binary release to fix that?
Regards,
Marco
