[Qgis-user] QGIS Windows build fails to load WMS with format image/jpeg
Tim Sutton
tim at linfiniti.com
Mon Aug 18 11:29:12 PDT 2008
Hi Marco
Hope you had a nice holiday :-) You wouldnt see any problems with dep
walker sinve qt image support for jpeg is via plugins. Also on your
dev system you probably wont see an issue since Qt will find the
plugins in the Qt dir. If you check main.cpp under src/app you will
see the seaerch path used for qt image plugins. Copy the image plugins
from qtdir/plugins/imageformats/* into the qgis dir using the expected
subdir. To test you can try renaming your qt dir before running qgis
and then doing e.g. Your wms test.
regards
Tim
On 8/18/08, Marco Pasetti <marcopstt at gmail.com> wrote:
> Hi Tim,
> what as rude awakening after 15 days of holidays :-) ... more that 800 mails
> to read and a lot of work to do!
> but the show must go on ! :)
>>I think this is just a packaging bug in that the qt jpeg drivers
>>probably arent packaged properly / at all. Marco Pasetti would be the
>>guy to go to on this.
> I don't think so. The specific qt jpeg library (as gif or png and others) is
> not needed in the package.
> I checked it out first with Dependency Walker and then tracked the specific
> WMS process with Process Manager: no erros found!
> I think it's a different problem. BTW it seems to work for me:
> http://www.webalice.it/marco.pasetti/qgis/Immagine01.png
> http://www.webalice.it/marco.pasetti/qgis/Immagine02.png
> Cheers,
> Marco
Sent from my mobile device
Tim Sutton
QGIS Project Steering Committee Member - Release Manager
Visit http://qgis.org for a great open source GIS
Blog: http://tim.linfiniti.com
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
