[Qgis-user] QGIS Windows build fails to load WMS with format	image/jpeg
    Stephan Holl
    stephan.holl at intevation.de
    Mon Aug 18 11:21:41 PDT 2008
Hello Marco,
"Marco Pasetti" <marcopstt at gmail.com>, [20080818-14:03:13]:
> Hi Tim,
> what as rude awakening after 15 days of holidays :-) ... more that
> 800 mails to read and a lot of work to do!
> but the show must go on ! :)
welcome back :-)
> >I think this is just a packaging bug in that the qt jpeg drivers
> >probably arent packaged properly / at all. Marco Pasetti would be the
> >guy to go to on this.
> I don't think so. The specific qt jpeg library (as gif or png and
> others) is not needed in the package.
> I checked it out first with Dependency Walker and then tracked the
> specific WMS process with Process Manager: no erros found!
> I think it's a different problem. BTW it seems to work for me:
> http://www.webalice.it/marco.pasetti/qgis/Immagine01.png
> http://www.webalice.it/marco.pasetti/qgis/Immagine02.png
Did you double check that the GetMap-request is done as jpeg?
Best regards
	Stephan
Stephan Holl <stephan.holl at intevation.de>, http://intevation.de/~stephan
Tel: +49 (0)541-33 50 8 32 | Intevation GmbH | AG Osnabrück - HR B 18998
Geschäftsführer:  Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20080818/a1ca64fa/attachment.sig>
