[Qgis-user] Write Coordinates to Attribute Table
Jacolin Yves
yjacolin at free.fr
Thu Aug 21 06:25:25 PDT 2008
Le Thursday 21 August 2008 15:11:57 Darren Cope, vous avez écrit :
> Hi all,
> I'm looking for a way to write X/Y coordinates for a point shapefile
> back into two columns (X/Y) in the shapefile's attribute table. Can
> QGIS do this? If so, how? If not, is there another open source tool
> that can perform this operation? Ideally, the less steps required the
> better, as this is something that will need to be repeated multiple
> times--thus a script would be ideal!
> Cheers,
> Darren Cope
> http://dmcope.freeshell.org
> http://bluesignweekly.blogspot.com/
> Qgis-user mailing list
You can use python modules as shapelib [1] or use a postgis script (SELECT
x(the_geom),y(the_geom) FROM ...).
Python script can be use inside QGIS (in the module shell) or in a plugin.
Y.
[1] http://trac.gispython.org/lab/wiki/Shapely
Yves Jacolin
http://softlibre.gloobe.org
