[Qgis-user] Write Coordinates to Attribute Table
    Yves Jacolin
    yjacolin at free.fr
    Sun Aug 24 09:47:19 PDT 2008
Darren,
Sorry I think I am wrong about the python module :(
I am not a python dev and not (yet) aware of the python modules inside QGIS,
but you should be definitively realise this dev with QGIS.
Y.
Le jeudi 21 août 2008 15:25, Jacolin Yves a écrit :
> Le Thursday 21 August 2008 15:11:57 Darren Cope, vous avez écrit :
> > Hi all,
> > I'm looking for a way to write X/Y coordinates for a point shapefile
> > back into two columns (X/Y) in the shapefile's attribute table.  Can
> > QGIS do this?  If so, how?  If not, is there another open source tool
> > that can perform this operation?  Ideally, the less steps required the
> > better, as this is something that will need to be repeated multiple
> > times--thus a script would be ideal!
> > Cheers,
> > Darren Cope
> > http://dmcope.freeshell.org
> > http://bluesignweekly.blogspot.com/
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> Hi,
> You can use python modules as shapelib [1] or use a postgis script (SELECT
> x(the_geom),y(the_geom) FROM ...).
> Python script can be use inside QGIS (in the module shell) or in a plugin.
> Y.
> [1] http://trac.gispython.org/lab/wiki/Shapely
Yves Jacolin
"Donner la liberté aux individus ne suffit pas, il faut aussi leur donner du
pouvoir, de la puissance d'agir." M Gauchet
"Give freedom to people is not enough, we also have to give them the power to
use this freedom, to act". M Gauchet
http://yjacolin.gloobe.org
http://softlibre.gloobe.org
