[Qgis-user] error loading python  qgis plugin
    Michele Ferretto
    michele.ferretto at tiscali.it
    Sat Aug 23 12:58:40 PDT 2008
I resolved. I've downgraded the python-qt4 package to version 4.3.3.
Thank you very much, Ron!!
Michele
Ron Bentley wrote:
> Michele,
> I understand it looks like a system configuration issue.
>> I 've tested your plugin but the result is the same; but my problem
>> relates ALL the plugins installed, none of them can start; I'm thinking
>> about s python-qt4 or python-sip4 issue: I've installed the 4.4.3 and
>> 4.4.7 version, respectively
> Since our setups are at least somewhat similar, I'll hazard one last
> post to give you something to compare against.
> I've got python-qt4, 4.3.3, and (oddly) python-qt4-dev, 4.4.2.  I also
> have python-sip4 and python-sip4-dev, 4.7.6 -- all from Debian testing.
> The qgis packages I have installed are qgis, qgis-plugin-grass,
> libqgis-core0.10, libqgis-gui0.10, and libqgisgrass0.10.  All are
> 0.10.0-2 from the debian.gfoss.it repository.
> Ron
