[Qgis-user] QGIS looses toolbar icons after changing background color
Maciej Sieczka
tutey at o2.pl
Sun Aug 31 04:58:33 PDT 2008
Nikos Alexandris pisze:
> Hi Maciek!
> I've been sneaking your scripts for osgeo software compilation. You use
> a "--with-autoload=loc_gdal_plugins" option while configuring the
> gdal-grass-plugin.
> I think you load/source this variable from a file/script called
> "build_vars.sh".
Yes, the build_vars.sh is sourced and the variable is defined there.
> I suppose this variable points to the gdal_plugins
> directory (i.e. /usr/local/lib/gdalplugins), right?
Check in the build_vars.sh I sent you (yes).
Maciek
Maciej Sieczka
www.sieczka.org
