[Qgis-user] QGIS looses toolbar icons after changing background color
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Sun Aug 31 04:59:54 PDT 2008
On Sun, 2008-08-31 at 13:58 +0200, Maciej Sieczka wrote:
> Nikos Alexandris pisze:
> > Hi Maciek!
> > I've been sneaking your scripts for osgeo software compilation. You use
> > a "--with-autoload=loc_gdal_plugins" option while configuring the
> > gdal-grass-plugin.
> > I think you load/source this variable from a file/script called
> > "build_vars.sh".
> Yes, the build_vars.sh is sourced and the variable is defined there.
> > I suppose this variable points to the gdal_plugins
> > directory (i.e. /usr/local/lib/gdalplugins), right?
> Check in the build_vars.sh I sent you (yes).
> Maciek
Ohhh! I am sorry for time-crunching. I didn't notice it. Thank you,
Nikos
