[Qgis-user] Re: Qgis-user Digest, Vol 34, Issue 3
Borys Jurgiel borys at wolf.most.org.pl
Wed Dec 3 05:08:46 PST 2008
Wednesday 03 of December 2008 13:44:05 Maurício de Paulo napisał(a):
> (actually I implemented it in a different way in the first time, but now it
> should work as expected). Now if the box is checked the first action is to
> select every feature in the layer. I've started using an script to clean
> and pack the scripts. I didn't know about the pyc problem.
I didn't too, but I've observed strange things on Windows ;)
> The extent
> shouldn't be a problem as I inserted an updateExtents() in the end before
> the zoomToSelected(). I hope now it's ok.
Everything works ok now, except this one. I'm using trunk and a layer in epsg
2180 as well as in wgs84. Look:
1. I open a layer. The X coordinates are about 600 000m:
   http://www.bwj.aster.net.pl/temp/affine1.png
2. After stretching 2x everything looks ok - X coordinates have growed up
   to ap. 1200 000m:
   http://www.bwj.aster.net.pl/temp/affine2.png
3. If I close the layer and load it back, the coordinates are ok (120 000m),
   but 'Zoom to layer extent' stretches from inital ~ 600 000 up to
   transformed ~ 1 200 000:
   http://www.bwj.aster.net.pl/temp/affine3.png
