[Qgis-user] [solved] QGIS segmentation fault
H.S.Rai
hs at raiandrai.com
Thu Dec 25 16:32:42 PST 2008
Today's updation, made qGIS - 1.0.0 Kore works fine on Ubuntu 8.10
On Sun, Nov 23, 2008 at 8:01 PM, Nikos Alexandris
<nikos.alexandris at felis.uni-freiburg.de> wrote:
> On Fri, 2008-11-21 at 23:31 +0200, Tim Sutton wrote:
>> Hi Gavin
>> On Fri, 2008-11-21 at 08:36 +0200, Gavin Fleming wrote:
>> > Hi
>> > Ubuntu server 7.10. QGIS worked until I did an apt-get update some
>> > time back. It was using standard repositories plus the
>> > launchpad/timlinux one. Yesterday I added launchpad/qgis to my apt
>> > sources and tried a new install but I still get this, I'm not even
>> > sure what version it's attempting to run. The splash screen was coming
>> > up in earlier versions of this crash but now that's not even
>> > happening:
>> Try purging all QGIS related packages and uninstalling any hand built
>> QGIS you may have, and then installing the launchpad/jef packages listed
>> on http://download.qgis.org for heron. That will get you 1.0 preview 2
>> which is IMHO more stable than 0.11 anyway.
>> Buzz if you still cant come right.
>> Regards
>> Tim
>> > qgis
>> > Warning: No valid projection. Unable to set map units.
>> > Segmentation fault
>> > Any tips?
>> > Gavin
> Hi all!
> That is what I do when things go wrong (under Ubuntu-64bit).
> *** BE CAREFUL with (1) "rm -rf" and (b) with /home/user-id/.qgis ***
> # in case of compiling another qgis version, before installing remove
> all qgis related stuff
> #for qgis_0_11
> sudo rm -rf /usr/local/bin/qgis \
> /usr/local/bin/qgis_help \
> /usr/local/include/qgis \
> /usr/local/lib/libqgis_core.so \
> /usr/local/lib/libqgis_core.so.0.11 \
> /usr/local/lib/libqgis_gui.so \
> /usr/local/lib/libqgis_gui.so.0.11 \
> /usr/local/lib/libqgisgrass.so \
> /usr/local/lib/libqgisgrass.so.0.11 \
> /usr/local/lib/libqgispython.so \
> /usr/local/lib/libqgispython.so.0.11 \
> /usr/local/lib/qgis \
> /usr/local/share/qgis \
> /usr/local/share/man/man1/qgis.man
> # for qgis 1.0
> sudo rm -rf /usr/local/lib/libqgis_core.so.1.0 \
> /usr/local/lib/libqgis_gui.so.1.0 \
> /usr/local/lib/libqgispython.so.1.0 \
> #/home/nik/.qgis
> Qgis-user mailing list
Dr. H.S.Rai
Prof. and Head
Civil Engineering Department http://gndec.ac.in/civil/
Guru Nanak Dev Engg. College http://gndec.ac.in/
Ludhiana (Pb) India
http://gndec.ac.in/~hsrai/
http://hs.raiandrai.com
