[Qgis-user] WMS in QGIS: no map displayed
Yves Jacolin
yjacolin at free.fr
Sun Feb 24 10:41:19 PST 2008
I just tested the QGIS in Trunk and I succeed to use my own WMS and WFS
webservice with mapserver (and a new GDAL build, 1.5.x). I think my problem
either has been corrected or I have a problem in my professional webservice
(I am using two differents old GDAL binaries releases : 1.3.2 and 1.4.1 :( )
Y.
Le vendredi 15 février 2008 12:13, Marco Hugentobler a écrit :
> Hi Yves,
> What is the capabilities output for the layer departements? I have no
> problem with the wms layers I'm using here, so it may have something to do
> about how the server specifies the bounding box in your particular case and
> how QGIS interprets it.
> Regards,
> Marco
> Am Donnerstag 14 Februar 2008 14:08:13 schrieb Jacolin Yves:
> > Hi,
> > I send again this email in order to know if this is a known bug.
> > The description was:
> > > I have a small problem with my own WMS service. I don't know where to
> > > ask, as you can see, it is not easy to find the reason of my problem.
> > > Description: A WMS Service is hosted in my localhost, using mapserver
> > > 4.10.3. This WMS is working with my navigator (by requesting directly
> > > the server), with gvSIG.
> > > With QGIS, this is completly different, this is not link to one
> > > release as I tested it with the 0.8.1, 0.9.1 and the futur 0.9.2. The
> > > layer is loaded in QGIS, nothing appear in the map windows, if I
> > > click right on the layer name to load the properties windows, I can
> > > see the result of the GetCapabilities request (well I suppose that it
> > > is a result from the GetCapabilities request). I can see all
> > > information about my layers.
> > > Do you know why my map does not appear in the map windows ?
> > Yes I know ;) ...
> > I find where the problem is:
> > Here is the request send by QGIS:
> > http://localhost/cgi-bin/mapserv_wms?
> > SERVICE=WMS&VERSION=1.0.0&
> > REQUEST=GetMap&
> > BBOX=203772.550229,2397786.527221,289662.028017,2470855.241209&
> > SRS=EPSG:27582&
> > WIDTH=892&HEIGHT=758&
> > LAYERS=departements&
> > FORMAT=image/png&TRANSPARENT=TRUE
> > Here is the correct one (the boox is not equivalent to the last request
> > but both are close to Paris, France):
> > http://localhost/cgi-bin/mapserv_wms?SERVICE=WMS&
> > VERSION=1.1.1&REQUEST=GetMap&
> > BBOX=601145.6388854936,2424122.2621656144,604743.970275728,2426768.09407
> >01 99& SRS=EPSG:27582&
> > FORMAT=jpeg&TRANSPARENT=TRUE
> > The two bbox are **completly** different! And the second one
> > (601145,2424122) seems correct to me.
> > All projections are correct: projection project: 27582, mapfile: 27582,
> > etc.
> > Any ideas?
> > Y.
Yves Jacolin
http://yjacolin.gloobe.org
http://softlibre.gloobe.org
