[Qgis-user] QGis v0.10.0: Digitizing & v.in.shape?
Marco Hugentobler marco.hugentobler at karto.baug.ethz.ch
Wed Jul 2 07:29:52 PDT 2008
Hi cuxland
To digitize, press the toggle edit button (with the pencil). Then choose an
editing tool to digitize. To split features, choose the split tool (scissor),
left clicks into map canvas to create the spliting line, finish split line
with right mouse button. The (line or polygon) features should then be split.
After editing, press the toggle edit button again and then you are asked if
you want to save your edits or roll back.
> By the way: is there a possibility to combine 2 lines? I haven't found such
> a thing.
At the moment, there is no merge tool.
The geoprocessing has the possibility to do union, but afaik only on dataset
level, not on feature level.
Regards,
Marco
Am Mittwoch 02 Juli 2008 15:57:06 schrieb cuxland:
> Hi list,
> sinced my searches in this list weren't successfull I ask now:
> Somehow I do not understand how the button for digitizing ('Objekte
> trennen', 'splitting objects'(?)) should work. Everything I tried so far
> was without any effect.
> a thing.
> Because of this I tried to use the Grass (inside QGis) digitizing
> functionality. But here another problem occurred: most of my data is stored
> as shp-files. So I tried to import them to Grass-QGis just to find out
> v.in.shape is not installed. Is there a way to install it afterwards?
> Thank you for help!
> cuxland
Dr. Marco Hugentobler
Institute of Cartography
ETH Zurich
Technical Advisor QGIS Project Steering Committee
