[Qgis-user] Configuring with ccmake, BINDINGS_GLOBAL_INSTALL
Salvator*eL*arosa s_larosa at libero.it
Tue Jul 22 08:27:44 PDT 2008
Craig Leat wrote:
> Hi
> I am attempting to build qgis trunk for the first time and I'm having
> some trouble configuring with ccmake. I'm stuck on the option:
> "BINDINGS_GLOBAL_INSTALL: Install bindings to global python directory?
> (might need root)" and although I have tried "yes" and "no" (as normal
> user and as root) I am unable to proceed. I have attached the file
> CMakeCache.txt in case I have missed some dependency.
> My system:
> qgis trunk revision 8821
> ubuntu 7.10 (32 bit)
> python 2.5.1
> Built from source: gdal 1.5, GRASS 6.4, GRASS plugin
> All other packages installed from the ubuntu repositories.
> All pointers are welcome, thanks
> Craig
> # This is the CMakeCache file.
> # For build in directory: /usr/local/src/qgis/build
> # It was generated by CMake: /usr/bin/cmake
> # You can edit this file to change values found and used by cmake.
> # If you do not want to change any of the values, simply exit the editor.
> # If you do want to change a value, simply edit, save, and exit the
> editor.
> # The syntax for the file is as follows:
> # KEY:TYPE=VALUE
> # KEY is the name of a variable in the cache.
> # TYPE is a hint to GUI's for the type of VALUE, DO NOT EDIT TYPE!.
> # VALUE is the current value for the KEY.
> # EXTERNAL cache entries
> //Install bindings to global python directory? (might need root)
> BINDINGS_GLOBAL_INSTALL:BOOL=ON
> //Path to a program.
> BISON_EXECUTABLE:FILEPATH=/usr/bin/bison
> CMAKE_AR:FILEPATH=/usr/bin/ar
> //For backwards compatibility, what version of CMake commands and
> // syntax should this version of CMake allow.
> CMAKE_BACKWARDS_COMPATIBILITY:STRING=2.4
> //Choose the type of build, options are: None(CMAKE_CXX_FLAGS or
> // CMAKE_C_FLAGS used) Debug Release RelWithDebInfo MinSizeRel.
> CMAKE_BUILD_TYPE:STRING=
> //Enable/Disable color output during build.
> CMAKE_COLOR_MAKEFILE:BOOL=ON
> //CXX compiler.
> CMAKE_CXX_COMPILER:FILEPATH=/usr/bin/c++
> //Flags used by the compiler during all build types.
> CMAKE_CXX_FLAGS:STRING=' '
> //Flags used by the compiler during debug builds.
> CMAKE_CXX_FLAGS_DEBUG:STRING=-g
> //Flags used by the compiler during release minsize builds.
> CMAKE_CXX_FLAGS_MINSIZEREL:STRING=-Os -DNDEBUG
> //Flags used by the compiler during release builds (/MD /Ob1 /Oi
> // /Ot /Oy /Gs will produce slightly less optimized but smaller
> // files).
> CMAKE_CXX_FLAGS_RELEASE:STRING=-O3 -DNDEBUG
> //Flags used by the compiler during Release with Debug Info builds.
> CMAKE_CXX_FLAGS_RELWITHDEBINFO:STRING=-O2 -g
> //C compiler.
> CMAKE_C_COMPILER:FILEPATH=/usr/local/bin/gcc
> //Flags for C compiler.
> CMAKE_C_FLAGS:STRING=' '
> CMAKE_C_FLAGS_DEBUG:STRING=-g
> CMAKE_C_FLAGS_MINSIZEREL:STRING=-Os -DNDEBUG
> // files).
> CMAKE_C_FLAGS_RELEASE:STRING=-O3 -DNDEBUG
> CMAKE_C_FLAGS_RELWITHDEBINFO:STRING=-O2 -g
> //Flags used by the linker.
> CMAKE_EXE_LINKER_FLAGS:STRING=
> //Flags used by the linker during debug builds.
> CMAKE_EXE_LINKER_FLAGS_DEBUG:STRING=
> //Flags used by the linker during release minsize builds.
> CMAKE_EXE_LINKER_FLAGS_MINSIZEREL:STRING=
> //Flags used by the linker during release builds.
> CMAKE_EXE_LINKER_FLAGS_RELEASE:STRING=
> //Flags used by the linker during Release with Debug Info builds.
> CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO:STRING=
> //Install path prefix, prepended onto install directories.
> CMAKE_INSTALL_PREFIX:PATH=/usr/local/src/qgis/run
> CMAKE_MAKE_PROGRAM:FILEPATH=/usr/bin/make
> //Flags used by the linker during the creation of modules.
> CMAKE_MODULE_LINKER_FLAGS:STRING=
> CMAKE_MODULE_LINKER_FLAGS_DEBUG:STRING=
> CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL:STRING=
> CMAKE_MODULE_LINKER_FLAGS_RELEASE:STRING=
> CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO:STRING=
> CMAKE_RANLIB:FILEPATH=/usr/bin/ranlib
> //Flags used by the linker during the creation of dll's.
> CMAKE_SHARED_LINKER_FLAGS:STRING=
> CMAKE_SHARED_LINKER_FLAGS_DEBUG:STRING=
> CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL:STRING=
> CMAKE_SHARED_LINKER_FLAGS_RELEASE:STRING=
> CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO:STRING=
> //If set, runtime paths are not added when using shared libraries.
> CMAKE_SKIP_RPATH:BOOL=NO
> //If true, cmake will use relative paths in makefiles and projects.
> CMAKE_USE_RELATIVE_PATHS:BOOL=OFF
> //If this value is on, makefiles will be generated without the
> // .SILENT directive, and all commands will be echoed to the console
> // during the make.  This is useful for debugging only. With Visual
> // Studio IDE projects all commands are done without /nologo.
> CMAKE_VERBOSE_MAKEFILE:BOOL=FALSE
> //Build unit tests?
> ENABLE_TESTS:BOOL=FALSE
> //Single output directory for building all executables.
> EXECUTABLE_OUTPUT_PATH:PATH=
> //Path to a file.
> EXPAT_INCLUDE_DIR:PATH=/usr/include
> //Path to a library.
> EXPAT_LIBRARY:FILEPATH=/usr/lib/libexpat.so
> FLEX_EXECUTABLE:FILEPATH=/usr/bin/flex
> GDAL_CONFIG:FILEPATH=/usr/local/bin/gdal-config
> //preferred path to GDAL (gdal-config) from FWTools
> GDAL_CONFIG_PREFER_FWTOOLS_PATH:STRING=
> GDAL_CONFIG_PREFER_PATH:STRING=
> //Path to a file.
> GDAL_INCLUDE_DIR:PATH=/usr/local/include
> //INTERNAL
> GDAL_LIBRARY:STRING=/usr/local/lib/libgdal.so
> //Path to a file.
> GEOS_INCLUDE_DIR:PATH=/usr/include
> GEOS_LIBRARY:FILEPATH=/usr/lib/libgeos.so
> //Path to a file.
> GRASS_INCLUDE_DIR:PATH=/usr/local/src/grass6_devel/dist.i686-pc-linux-gnu/include
> //Path to GRASS base directory
> GRASS_PREFIX:PATH=/usr/local/src/grass6_devel/dist.i686-pc-linux-gnu
> GSL_CONFIG:FILEPATH=/usr/bin/gsl-config
> //preferred path to GSL (gsl-config)
> GSL_CONFIG_PREFER_PATH:STRING=
> //INTERNAL
> GSL_EXE_LINKER_FLAGS:STRING=-Wl,-rpath,/usr/lib
> //INTERNAL
> GSL_INCLUDE_DIR:STRING=/usr/include
> //Single output directory for building all libraries.
> LIBRARY_OUTPUT_PATH:PATH=
> LIB_PATH:FILEPATH=/usr/local/src/grass6_devel/dist.i686-pc-linux-gnu/lib/libgrass_gproj.so
> OPENPTY_LIBRARY:FILEPATH=/usr/lib/libutil.so
> //Determines if we should compile with -Wall -Werror.
> PEDANTIC:BOOL=FALSE
> //Path to POSTGRESQL base directory
> POSTGRESQL_PREFIX:PATH=
> POSTGRES_CONFIG:FILEPATH=/usr/bin/pg_config
> //preferred path to PG (pg_config)
> POSTGRES_CONFIG_PREFER_PATH:STRING=/bin
> //INTERNAL
> POSTGRES_INCLUDE_DIR:STRING=/usr/include/postgresql
> //INTERNAL
> POSTGRES_LIBRARY:STRING=/usr/lib/libpq.so
> //Path to a file.
> PROJ_INCLUDE_DIR:PATH=/usr/include
> PROJ_LIBRARY:FILEPATH=/usr/lib/libproj.so
> PYTHON_EXECUTABLE:FILEPATH=/usr/bin/python2.5
> //Path to a file.
> PYTHON_INCLUDE_PATH:PATH=/usr/include/python2.5
> PYTHON_LIBRARY:FILEPATH=/usr/lib/python2.5/config/libpython2.5.so
> //Subdirectory where executables will be installed
> QGIS_BIN_SUBDIR:STRING=bin
> //Subdirectory where QGIS data will be installed
> QGIS_DATA_SUBDIR:STRING=share/qgis
> //Subdirectory where header files will be installed
> QGIS_INCLUDE_SUBDIR:STRING=include/qgis
> //Subdirectory where libraries will be installed
> QGIS_LIB_SUBDIR:STRING=lib
> //Subdirectory where manual files will be installed
> QGIS_MANUAL_SUBDIR:STRING=man
> //Subdirectory where plugins will be installed
> QGIS_PLUGIN_SUBDIR:STRING=lib/qgis
> //The location of the Qt docs
> QT_DOC_DIR:PATH=/usr/share/qt4/doc
> QT_FONTCONFIG_LIBRARY:FILEPATH=/usr/lib/libfontconfig.so
> QT_FREETYPE_LIBRARY:FILEPATH=/usr/lib/libfreetype.so
> //Missing description
> QT_INCLUDE_DIR:PATH=/usr/include/qt4
> //Qt library dir
> QT_LIBRARY_DIR:PATH=/usr/lib
> QT_LRELEASE_EXECUTABLE:FILEPATH=/usr/bin/lrelease
> //The location of the Qt mkspecs
> QT_MKSPECS_DIR:PATH=/usr/share/qt4/mkspecs
> //The moc executable
> QT_MOC_EXECUTABLE:FILEPATH=/usr/bin/moc-qt4
> //The location of the Qt plugins
> QT_PLUGINS_DIR:PATH=/usr/lib/qt4/plugins
> QT_PNG_LIBRARY:FILEPATH=/usr/lib/libpng.so
> QT_QMAKE_EXECUTABLE:FILEPATH=/usr/bin/qmake
> //Path to a file.
> QT_QT3SUPPORT_INCLUDE_DIR:PATH=/usr/include/qt4/Qt3Support
> //The Qt QT3SUPPORT library
> QT_QT3SUPPORT_LIBRARY:FILEPATH=/usr/lib/libQt3Support.so
> QT_QT3SUPPORT_LIBRARY_DEBUG:FILEPATH=QT_QT3SUPPORT_LIBRARY_DEBUG-NOTFOUND
> QT_QT3SUPPORT_LIBRARY_RELEASE:FILEPATH=/usr/lib/libQt3Support.so
> //Path to a file.
> QT_QTASSISTANT_INCLUDE_DIR:PATH=/usr/include/qt4/QtAssistant
> //The Qt QTASSISTANT library
> QT_QTASSISTANT_LIBRARY:FILEPATH=/usr/lib/libQtAssistantClient.so
> QT_QTASSISTANT_LIBRARY_DEBUG:FILEPATH=QT_QTASSISTANT_LIBRARY_DEBUG-NOTFOUND
> QT_QTASSISTANT_LIBRARY_RELEASE:FILEPATH=/usr/lib/libQtAssistantClient.so
> //Path to a file.
> QT_QTCORE_INCLUDE_DIR:PATH=/usr/include/qt4/QtCore
> //The Qt QTCORE library
> QT_QTCORE_LIBRARY:FILEPATH=/usr/lib/libQtCore.so
> QT_QTCORE_LIBRARY_DEBUG:FILEPATH=QT_QTCORE_LIBRARY_DEBUG-NOTFOUND
> QT_QTCORE_LIBRARY_RELEASE:FILEPATH=/usr/lib/libQtCore.so
> //Path to a file.
> QT_QTDESIGNER_INCLUDE_DIR:PATH=/usr/include/qt4/QtDesigner
> //The Qt QTDESIGNER library
> QT_QTDESIGNER_LIBRARY:FILEPATH=/usr/lib/libQtDesigner.so
> QT_QTDESIGNER_LIBRARY_DEBUG:FILEPATH=QT_QTDESIGNER_LIBRARY_DEBUG-NOTFOUND
> QT_QTDESIGNER_LIBRARY_RELEASE:FILEPATH=/usr/lib/libQtDesigner.so
> //Path to a file.
> QT_QTGUI_INCLUDE_DIR:PATH=/usr/include/qt4/QtGui
> //The Qt QTGUI library
> QT_QTGUI_LIBRARY:FILEPATH=/usr/lib/libQtGui.so
> QT_QTGUI_LIBRARY_DEBUG:FILEPATH=QT_QTGUI_LIBRARY_DEBUG-NOTFOUND
> QT_QTGUI_LIBRARY_RELEASE:FILEPATH=/usr/lib/libQtGui.so
> //Path to a file.
> QT_QTMOTIF_INCLUDE_DIR:PATH=QT_QTMOTIF_INCLUDE_DIR-NOTFOUND
> QT_QTMOTIF_LIBRARY_DEBUG:FILEPATH=QT_QTMOTIF_LIBRARY_DEBUG-NOTFOUND
> QT_QTMOTIF_LIBRARY_RELEASE:FILEPATH=QT_QTMOTIF_LIBRARY_RELEASE-NOTFOUND
> //Path to a file.
> QT_QTNETWORK_INCLUDE_DIR:PATH=/usr/include/qt4/QtNetwork
> //The Qt QTNETWORK library
> QT_QTNETWORK_LIBRARY:FILEPATH=/usr/lib/libQtNetwork.so
> QT_QTNETWORK_LIBRARY_DEBUG:FILEPATH=QT_QTNETWORK_LIBRARY_DEBUG-NOTFOUND
> QT_QTNETWORK_LIBRARY_RELEASE:FILEPATH=/usr/lib/libQtNetwork.so
> //Path to a file.
> QT_QTNSPLUGIN_INCLUDE_DIR:PATH=QT_QTNSPLUGIN_INCLUDE_DIR-NOTFOUND
> QT_QTNSPLUGIN_LIBRARY_DEBUG:FILEPATH=QT_QTNSPLUGIN_LIBRARY_DEBUG-NOTFOUND
> QT_QTNSPLUGIN_LIBRARY_RELEASE:FILEPATH=QT_QTNSPLUGIN_LIBRARY_RELEASE-NOTFOUND
> //Path to a file.
> QT_QTOPENGL_INCLUDE_DIR:PATH=/usr/include/qt4/QtOpenGL
> //The Qt QTOPENGL library
> QT_QTOPENGL_LIBRARY:FILEPATH=/usr/lib/libQtOpenGL.so
> QT_QTOPENGL_LIBRARY_DEBUG:FILEPATH=QT_QTOPENGL_LIBRARY_DEBUG-NOTFOUND
> QT_QTOPENGL_LIBRARY_RELEASE:FILEPATH=/usr/lib/libQtOpenGL.so
> //Path to a file.
> QT_QTSQL_INCLUDE_DIR:PATH=/usr/include/qt4/QtSql
> //The Qt QTSQL library
> QT_QTSQL_LIBRARY:FILEPATH=/usr/lib/libQtSql.so
> QT_QTSQL_LIBRARY_DEBUG:FILEPATH=QT_QTSQL_LIBRARY_DEBUG-NOTFOUND
> QT_QTSQL_LIBRARY_RELEASE:FILEPATH=/usr/lib/libQtSql.so
> //Path to a file.
> QT_QTSVG_INCLUDE_DIR:PATH=/usr/include/qt4/QtSvg
> //The Qt QTSVG library
> QT_QTSVG_LIBRARY:FILEPATH=/usr/lib/libQtSvg.so
> QT_QTSVG_LIBRARY_DEBUG:FILEPATH=QT_QTSVG_LIBRARY_DEBUG-NOTFOUND
> QT_QTSVG_LIBRARY_RELEASE:FILEPATH=/usr/lib/libQtSvg.so
> //Path to a file.
> QT_QTTEST_INCLUDE_DIR:PATH=/usr/include/qt4/QtTest
> //The Qt QTTEST library
> QT_QTTEST_LIBRARY:FILEPATH=/usr/lib/libQtTest.so
> QT_QTTEST_LIBRARY_DEBUG:FILEPATH=QT_QTTEST_LIBRARY_DEBUG-NOTFOUND
> QT_QTTEST_LIBRARY_RELEASE:FILEPATH=/usr/lib/libQtTest.so
> //Path to a file.
> QT_QTUITOOLS_INCLUDE_DIR:PATH=/usr/include/qt4/QtUiTools
> //The Qt QTUITOOLS library
> QT_QTUITOOLS_LIBRARY:FILEPATH=/usr/lib/libQtUiTools.a
> QT_QTUITOOLS_LIBRARY_DEBUG:FILEPATH=QT_QTUITOOLS_LIBRARY_DEBUG-NOTFOUND
> QT_QTUITOOLS_LIBRARY_RELEASE:FILEPATH=/usr/lib/libQtUiTools.a
> //Path to a file.
> QT_QTXML_INCLUDE_DIR:PATH=/usr/include/qt4/QtXml
> //The Qt QTXML library
> QT_QTXML_LIBRARY:FILEPATH=/usr/lib/libQtXml.so
> QT_QTXML_LIBRARY_DEBUG:FILEPATH=QT_QTXML_LIBRARY_DEBUG-NOTFOUND
> QT_QTXML_LIBRARY_RELEASE:FILEPATH=/usr/lib/libQtXml.so
> //Path to a file.
> QT_QT_INCLUDE_DIR:PATH=/usr/include/qt4/Qt
> QT_RCC_EXECUTABLE:FILEPATH=/usr/bin/rcc
> QT_UIC3_EXECUTABLE:FILEPATH=/usr/bin/uic3
> //The uic executable
> QT_UIC_EXECUTABLE:FILEPATH=/usr/bin/uic-qt4
> QT_X11_ICE_LIBRARY:FILEPATH=/usr/lib/libICE.so
> QT_X11_SM_LIBRARY:FILEPATH=/usr/lib/libSM.so
> QT_X11_X11_LIBRARY:FILEPATH=/usr/lib/libX11.so
> QT_X11_Xext_LIBRARY:FILEPATH=/usr/lib/libXext.so
> QT_X11_m_LIBRARY:FILEPATH=/usr/lib/libm.so
> QT_XCURSOR_LIBRARY:FILEPATH=/usr/lib/libXcursor.so
> QT_XINERAMA_LIBRARY:FILEPATH=/usr/lib/libXinerama.so
> QT_XI_LIBRARY:FILEPATH=/usr/lib/libXi.so
> QT_XRANDR_LIBRARY:FILEPATH=/usr/lib/libXrandr.so
> QT_XRENDER_LIBRARY:FILEPATH=/usr/lib/libXrender.so
> QT_ZLIB_LIBRARY:FILEPATH=/usr/lib/libz.so
> SIP_BINARY_PATH:FILEPATH=/usr/bin/sip
> //Path to a file.
> SIP_INCLUDE_DIR:PATH=/usr/include/python2.5
> //Path to a file.
> SQLITE3_INCLUDE_DIR:PATH=/usr/include
> SQLITE3_LIBRARY:FILEPATH=/usr/lib/libsqlite3.so
> //Path to a file.
> SVN_MARKER:FILEPATH=/usr/local/src/qgis/.svn/entries
> //Determines whether python bindings should be built
> WITH_BINDINGS:BOOL=TRUE
> //Determines whether GRASS plugin should be built
> WITH_GRASS:BOOL=TRUE
> //Compile sqlite3 support directly into the binary
> WITH_INTERNAL_SQLITE3:BOOL=FALSE
> //Determines whether POSTGRESQL support should be built
> WITH_POSTGRESQL:BOOL=TRUE
> //Dependencies for the target
> copyrightlabelplugin_LIB_DEPENDS:STATIC=qgis_core;qgis_gui;
> delimitedtextplugin_LIB_DEPENDS:STATIC=qgis_core;qgis_gui;
> delimitedtextprovider_LIB_DEPENDS:STATIC=/usr/lib/libQtCore.so;/usr/lib/libQtXml.so;/usr/local/lib/libgdal.so;/usr/lib/libgeos.so;qgis_core;
> georefplugin_LIB_DEPENDS:STATIC=qgis_core;qgis_gui;-L/usr/lib -lgsl
> -lgslcblas -lm;
> gpsimporterplugin_LIB_DEPENDS:STATIC=qgis_core;qgis_gui;
> gpxprovider_LIB_DEPENDS:STATIC=/usr/lib/libQtCore.so;/usr/lib/libQtXml.so;/usr/lib/libgeos.so;/usr/lib/libexpat.so;qgis_core;
> grassplugin_LIB_DEPENDS:STATIC=qgis_core;qgis_gui;qgisgrass;/usr/local/src/grass6_devel/dist.i686-pc-linux-gnu/lib/libgrass_gis.so;/usr/local/src/grass6_devel/dist.i686-pc-linux-gnu/lib/libgrass_vect.so;/usr/local/src/grass6_devel/dist.i686-pc-linux-gnu/lib/libgrass_dig2.so;/usr/local/src/grass6_devel/dist.i686-pc-linux-gnu/lib/libgrass_dbmiclient.so;/usr/local/src/grass6_devel/dist.i686-pc-linux-gnu/lib/libgrass_dbmibase.so;/usr/local/src/grass6_devel/dist.i686-pc-linux-gnu/lib/libgrass_shape.so;/usr/local/src/grass6_devel/dist.i686-pc-linux-gnu/lib/libgrass_dgl.so;/usr/local/src/grass6_devel/dist.i686-pc-linux-gnu/lib/libgrass_rtree.so;/usr/local/src/grass6_devel/dist.i686-pc-linux-gnu/lib/libgrass_datetime.so;/usr/local/src/grass6_devel/dist.i686-pc-linux-gnu/lib/libgrass_linkm.so;/usr/local/src/grass6_devel/dist.i686-pc-linux-gnu/lib/libgrass_form.so;/usr/local/src/grass6_devel/dist.i686-pc-linux-gnu/lib/libgrass_gproj.so;/usr/lib/libutil.so;
> grassprovider_LIB_DEPENDS:STATIC=/usr/lib/libQtCore.so;/usr/lib/libQtXml.so;qgis_core;qgisgrass;
> gridmakerplugin_LIB_DEPENDS:STATIC=qgis_core;qgis_gui;
> memoryprovider_LIB_DEPENDS:STATIC=/usr/lib/libQtCore.so;qgis_core;
> northarrowplugin_LIB_DEPENDS:STATIC=qgis_core;qgis_gui;
> ogrprovider_LIB_DEPENDS:STATIC=/usr/lib/libQtCore.so;/usr/lib/libQtXml.so;/usr/local/lib/libgdal.so;/usr/lib/libgeos.so;qgis_core;
> pggeoprocessingplugin_LIB_DEPENDS:STATIC=/usr/lib/libpq.so;qgis_core;qgis_gui;
> postgresprovider_LIB_DEPENDS:STATIC=/usr/lib/libQtCore.so;/usr/lib/libQtXml.so;/usr/lib/libpq.so;qgis_core;
> //Value Computed by CMake
> qgis1.0.0_BINARY_DIR:STATIC=/usr/local/src/qgis/build
> qgis1.0.0_SOURCE_DIR:STATIC=/usr/local/src/qgis
> qgis_core_LIB_DEPENDS:STATIC=/usr/lib/libQtCore.so;/usr/lib/libQtGui.so;/usr/lib/libQtXml.so;/usr/lib/libQtSvg.so;/usr/lib/libQtNetwork.so;/usr/lib/libproj.so;/usr/lib/libgeos.so;/usr/local/lib/libgdal.so;/usr/lib/libsqlite3.so;
> qgis_gui_LIB_DEPENDS:STATIC=/usr/lib/libQtGui.so;/usr/lib/libQtXml.so;/usr/lib/libQtSvg.so;/usr/lib/libQtNetwork.so;qgis_core;
> qgisgrass_LIB_DEPENDS:STATIC=/usr/lib/libQtCore.so;/usr/lib/libQtXml.so;/usr/lib/libQt3Support.so;/usr/local/src/grass6_devel/dist.i686-pc-linux-gnu/lib/libgrass_gis.so;/usr/local/src/grass6_devel/dist.i686-pc-linux-gnu/lib/libgrass_vect.so;/usr/local/src/grass6_devel/dist.i686-pc-linux-gnu/lib/libgrass_dig2.so;/usr/local/src/grass6_devel/dist.i686-pc-linux-gnu/lib/libgrass_dbmiclient.so;/usr/local/src/grass6_devel/dist.i686-pc-linux-gnu/lib/libgrass_dbmibase.so;/usr/local/src/grass6_devel/dist.i686-pc-linux-gnu/lib/libgrass_shape.so;/usr/local/src/grass6_devel/dist.i686-pc-linux-gnu/lib/libgrass_dgl.so;/usr/local/src/grass6_devel/dist.i686-pc-linux-gnu/lib/libgrass_rtree.so;/usr/local/src/grass6_devel/dist.i686-pc-linux-gnu/lib/libgrass_datetime.so;/usr/local/src/grass6_devel/dist.i686-pc-linux-gnu/lib/libgrass_linkm.so;/usr/local/src/grass6_devel/dist.i686-pc-linux-gnu/lib/libgrass_form.so;/usr/local/src/grass6_devel/dist.i686-pc-linux-gnu/lib/libgrass_gproj.so;/usr/lib/libutil.so;qgis_core;
> qgispython_LIB_DEPENDS:STATIC=/usr/lib/libQtCore.so;/usr/lib/libQtGui.so;/usr/lib/python2.5/config/libpython2.5.so;util;qgis_core;
> quickprintplugin_LIB_DEPENDS:STATIC=qgis_core;qgis_gui;
> scalebarplugin_LIB_DEPENDS:STATIC=qgis_core;qgis_gui;
> spitplugin_LIB_DEPENDS:STATIC=/usr/lib/libpq.so;/usr/local/lib/libgdal.so;qgis_core;qgis_gui;
> wfsplugin_LIB_DEPENDS:STATIC=qgis_core;qgis_gui;
> wfsprovider_LIB_DEPENDS:STATIC=/usr/lib/libQtCore.so;/usr/lib/libQtXml.so;/usr/lib/libgeos.so;/usr/lib/libexpat.so;qgis_core;
> wmsprovider_LIB_DEPENDS:STATIC=/usr/lib/libQtCore.so;/usr/lib/libQtXml.so;qgis_core;
> # INTERNAL cache entries
> //Modified flag for variable: BINDINGS_GLOBAL_INSTALL
> BINDINGS_GLOBAL_INSTALL-MODIFIED:INTERNAL=1
> //Advanced flag for variable: CMAKE_AR
> CMAKE_AR-ADVANCED:INTERNAL=1
> //Advanced flag for variable: CMAKE_BUILD_TOOL
> CMAKE_BUILD_TOOL-ADVANCED:INTERNAL=1
> //What is the target build tool cmake is generating for.
> CMAKE_BUILD_TOOL:INTERNAL=/usr/bin/make
> //This is the directory where this CMakeCahe.txt was created
> CMAKE_CACHEFILE_DIR:INTERNAL=/usr/local/src/qgis/build
> //Major version of cmake used to create the current loaded cache
> CMAKE_CACHE_MAJOR_VERSION:INTERNAL=2
> //Minor version of cmake used to create the current loaded cache
> CMAKE_CACHE_MINOR_VERSION:INTERNAL=4
> CMAKE_CACHE_RELEASE_VERSION:INTERNAL=patch 7
> //Advanced flag for variable: CMAKE_COLOR_MAKEFILE
> CMAKE_COLOR_MAKEFILE-ADVANCED:INTERNAL=1
> //Path to CMake executable.
> CMAKE_COMMAND:INTERNAL=/usr/bin/cmake
> //Path to ctest program executable.
> CMAKE_CTEST_COMMAND:INTERNAL=/usr/bin/ctest
> //Advanced flag for variable: CMAKE_CXX_COMPILER
> CMAKE_CXX_COMPILER-ADVANCED:INTERNAL=1
> CMAKE_CXX_COMPILER_WORKS:INTERNAL=1
> //Advanced flag for variable: CMAKE_CXX_FLAGS
> CMAKE_CXX_FLAGS-ADVANCED:INTERNAL=1
> //Advanced flag for variable: CMAKE_CXX_FLAGS_DEBUG
> CMAKE_CXX_FLAGS_DEBUG-ADVANCED:INTERNAL=1
> //Advanced flag for variable: CMAKE_CXX_FLAGS_MINSIZEREL
> CMAKE_CXX_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
> //Advanced flag for variable: CMAKE_CXX_FLAGS_RELEASE
> CMAKE_CXX_FLAGS_RELEASE-ADVANCED:INTERNAL=1
> //Advanced flag for variable: CMAKE_CXX_FLAGS_RELWITHDEBINFO
> CMAKE_CXX_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
> //Advanced flag for variable: CMAKE_C_COMPILER
> CMAKE_C_COMPILER-ADVANCED:INTERNAL=1
> CMAKE_C_COMPILER_WORKS:INTERNAL=1
> //Advanced flag for variable: CMAKE_C_FLAGS
> CMAKE_C_FLAGS-ADVANCED:INTERNAL=1
> //Advanced flag for variable: CMAKE_C_FLAGS_DEBUG
> CMAKE_C_FLAGS_DEBUG-ADVANCED:INTERNAL=1
> //Advanced flag for variable: CMAKE_C_FLAGS_MINSIZEREL
> CMAKE_C_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
> //Advanced flag for variable: CMAKE_C_FLAGS_RELEASE
> CMAKE_C_FLAGS_RELEASE-ADVANCED:INTERNAL=1
> //Advanced flag for variable: CMAKE_C_FLAGS_RELWITHDEBINFO
> CMAKE_C_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
> //Path to cache edit program executable.
> CMAKE_EDIT_COMMAND:INTERNAL=/usr/bin/ccmake
> //Advanced flag for variable: CMAKE_EXE_LINKER_FLAGS
> CMAKE_EXE_LINKER_FLAGS-ADVANCED:INTERNAL=1
> //Advanced flag for variable: CMAKE_EXE_LINKER_FLAGS_DEBUG
> CMAKE_EXE_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1
> //Advanced flag for variable: CMAKE_EXE_LINKER_FLAGS_MINSIZEREL
> CMAKE_EXE_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
> //Advanced flag for variable: CMAKE_EXE_LINKER_FLAGS_RELEASE
> CMAKE_EXE_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1
> //Advanced flag for variable: CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO
> CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
> //Name of generator.
> CMAKE_GENERATOR:INTERNAL=Unix Makefiles
> //Start directory with the top level CMakeLists.txt file for this
> // project
> CMAKE_HOME_DIRECTORY:INTERNAL=/usr/local/src/qgis
> //Modified flag for variable: CMAKE_INSTALL_PREFIX
> CMAKE_INSTALL_PREFIX-MODIFIED:INTERNAL=1
> //Install .so files without execute permission.
> CMAKE_INSTALL_SO_NO_EXE:INTERNAL=1
> //Advanced flag for variable: CMAKE_MAKE_PROGRAM
> CMAKE_MAKE_PROGRAM-ADVANCED:INTERNAL=1
> //Advanced flag for variable: CMAKE_MODULE_LINKER_FLAGS
> CMAKE_MODULE_LINKER_FLAGS-ADVANCED:INTERNAL=1
> //Advanced flag for variable: CMAKE_MODULE_LINKER_FLAGS_DEBUG
> CMAKE_MODULE_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1
> //Advanced flag for variable: CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL
> CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
> //Advanced flag for variable: CMAKE_MODULE_LINKER_FLAGS_RELEASE
> CMAKE_MODULE_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1
> //Advanced flag for variable: CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO
> CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
> //number of local generators
> CMAKE_NUMBER_OF_LOCAL_GENERATORS:INTERNAL=52
> //Advanced flag for variable: CMAKE_RANLIB
> CMAKE_RANLIB-ADVANCED:INTERNAL=1
> //Path to CMake installation.
> CMAKE_ROOT:INTERNAL=/usr/share/cmake-2.4
> //Advanced flag for variable: CMAKE_SHARED_LINKER_FLAGS
> CMAKE_SHARED_LINKER_FLAGS-ADVANCED:INTERNAL=1
> //Advanced flag for variable: CMAKE_SHARED_LINKER_FLAGS_DEBUG
> CMAKE_SHARED_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1
> //Advanced flag for variable: CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL
> CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
> //Advanced flag for variable: CMAKE_SHARED_LINKER_FLAGS_RELEASE
> CMAKE_SHARED_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1
> //Advanced flag for variable: CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO
> CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
> //Result of TRY_RUN
> CMAKE_SIZEOF_VOID_P:INTERNAL=4
> //Advanced flag for variable: CMAKE_SKIP_RPATH
> CMAKE_SKIP_RPATH-ADVANCED:INTERNAL=1
> //uname command
> CMAKE_UNAME:INTERNAL=/bin/uname
> //Advanced flag for variable: CMAKE_USE_RELATIVE_PATHS
> CMAKE_USE_RELATIVE_PATHS-ADVANCED:INTERNAL=1
> //Advanced flag for variable: CMAKE_VERBOSE_MAKEFILE
> CMAKE_VERBOSE_MAKEFILE-ADVANCED:INTERNAL=1
> //Modified flag for variable: GDAL_CONFIG_PREFER_FWTOOLS_PATH
> GDAL_CONFIG_PREFER_FWTOOLS_PATH-MODIFIED:INTERNAL=1
> //Modified flag for variable: GDAL_CONFIG_PREFER_PATH
> GDAL_CONFIG_PREFER_PATH-MODIFIED:INTERNAL=1
> //Advanced flag for variable: GRASS_INCLUDE_DIR
> GRASS_INCLUDE_DIR-ADVANCED:INTERNAL=1
> //Modified flag for variable: GRASS_PREFIX
> GRASS_PREFIX-MODIFIED:INTERNAL=1
> //Modified flag for variable: GSL_CONFIG
> GSL_CONFIG-MODIFIED:INTERNAL=1
> //Modified flag for variable: GSL_CONFIG_PREFER_PATH
> GSL_CONFIG_PREFER_PATH-MODIFIED:INTERNAL=1
> //Advanced flag for variable: GSL_INCLUDE_DIR
> GSL_INCLUDE_DIR-ADVANCED:INTERNAL=1
> //Result of TRY_COMPILE
> HAVE_CMAKE_SIZEOF_VOID_P:INTERNAL=TRUE
> //Have function openpty
> HAVE_OPENPTY:INTERNAL=1
> //Advanced flag for variable: LIBRARY_OUTPUT_PATH
> LIBRARY_OUTPUT_PATH-ADVANCED:INTERNAL=1
> //Advanced flag for variable: LIB_PATH
> LIB_PATH-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QGIS_BIN_SUBDIR
> QGIS_BIN_SUBDIR-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QGIS_DATA_SUBDIR
> QGIS_DATA_SUBDIR-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QGIS_INCLUDE_SUBDIR
> QGIS_INCLUDE_SUBDIR-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QGIS_LIB_SUBDIR
> QGIS_LIB_SUBDIR-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QGIS_MANUAL_SUBDIR
> QGIS_MANUAL_SUBDIR-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QGIS_PLUGIN_SUBDIR
> QGIS_PLUGIN_SUBDIR-ADVANCED:INTERNAL=1
> QT_BINARY_DIR:INTERNAL=/usr/bin
> //Advanced flag for variable: QT_DOC_DIR
> QT_DOC_DIR-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_FONTCONFIG_LIBRARY
> QT_FONTCONFIG_LIBRARY-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_FREETYPE_LIBRARY
> QT_FREETYPE_LIBRARY-ADVANCED:INTERNAL=1
> QT_HEADERS_DIR:INTERNAL=/usr/include/qt4
> //Advanced flag for variable: QT_INCLUDE_DIR
> QT_INCLUDE_DIR-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_LIBRARY_DIR
> QT_LIBRARY_DIR-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_MOC_EXECUTABLE
> QT_MOC_EXECUTABLE-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_PNG_LIBRARY
> QT_PNG_LIBRARY-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QT3SUPPORT_INCLUDE_DIR
> QT_QT3SUPPORT_INCLUDE_DIR-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QT3SUPPORT_LIBRARY
> QT_QT3SUPPORT_LIBRARY-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QT3SUPPORT_LIBRARY_DEBUG
> QT_QT3SUPPORT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QT3SUPPORT_LIBRARY_RELEASE
> QT_QT3SUPPORT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTASSISTANT_INCLUDE_DIR
> QT_QTASSISTANT_INCLUDE_DIR-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTASSISTANT_LIBRARY
> QT_QTASSISTANT_LIBRARY-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTASSISTANT_LIBRARY_DEBUG
> QT_QTASSISTANT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTASSISTANT_LIBRARY_RELEASE
> QT_QTASSISTANT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTCORE_INCLUDE_DIR
> QT_QTCORE_INCLUDE_DIR-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTCORE_LIBRARY
> QT_QTCORE_LIBRARY-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTCORE_LIBRARY_DEBUG
> QT_QTCORE_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTCORE_LIBRARY_RELEASE
> QT_QTCORE_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTDESIGNER_INCLUDE_DIR
> QT_QTDESIGNER_INCLUDE_DIR-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTDESIGNER_LIBRARY
> QT_QTDESIGNER_LIBRARY-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTDESIGNER_LIBRARY_DEBUG
> QT_QTDESIGNER_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTDESIGNER_LIBRARY_RELEASE
> QT_QTDESIGNER_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTGUI_INCLUDE_DIR
> QT_QTGUI_INCLUDE_DIR-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTGUI_LIBRARY
> QT_QTGUI_LIBRARY-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTGUI_LIBRARY_DEBUG
> QT_QTGUI_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTGUI_LIBRARY_RELEASE
> QT_QTGUI_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTMOTIF_INCLUDE_DIR
> QT_QTMOTIF_INCLUDE_DIR-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTMOTIF_LIBRARY_DEBUG
> QT_QTMOTIF_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTMOTIF_LIBRARY_RELEASE
> QT_QTMOTIF_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTNETWORK_INCLUDE_DIR
> QT_QTNETWORK_INCLUDE_DIR-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTNETWORK_LIBRARY
> QT_QTNETWORK_LIBRARY-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTNETWORK_LIBRARY_DEBUG
> QT_QTNETWORK_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTNETWORK_LIBRARY_RELEASE
> QT_QTNETWORK_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTNSPLUGIN_INCLUDE_DIR
> QT_QTNSPLUGIN_INCLUDE_DIR-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTNSPLUGIN_LIBRARY_DEBUG
> QT_QTNSPLUGIN_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTNSPLUGIN_LIBRARY_RELEASE
> QT_QTNSPLUGIN_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTOPENGL_INCLUDE_DIR
> QT_QTOPENGL_INCLUDE_DIR-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTOPENGL_LIBRARY
> QT_QTOPENGL_LIBRARY-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTOPENGL_LIBRARY_DEBUG
> QT_QTOPENGL_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTOPENGL_LIBRARY_RELEASE
> QT_QTOPENGL_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTSQL_INCLUDE_DIR
> QT_QTSQL_INCLUDE_DIR-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTSQL_LIBRARY
> QT_QTSQL_LIBRARY-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTSQL_LIBRARY_DEBUG
> QT_QTSQL_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTSQL_LIBRARY_RELEASE
> QT_QTSQL_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTSVG_INCLUDE_DIR
> QT_QTSVG_INCLUDE_DIR-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTSVG_LIBRARY
> QT_QTSVG_LIBRARY-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTSVG_LIBRARY_DEBUG
> QT_QTSVG_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTSVG_LIBRARY_RELEASE
> QT_QTSVG_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTTEST_INCLUDE_DIR
> QT_QTTEST_INCLUDE_DIR-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTTEST_LIBRARY
> QT_QTTEST_LIBRARY-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTTEST_LIBRARY_DEBUG
> QT_QTTEST_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTTEST_LIBRARY_RELEASE
> QT_QTTEST_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTUITOOLS_INCLUDE_DIR
> QT_QTUITOOLS_INCLUDE_DIR-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTUITOOLS_LIBRARY
> QT_QTUITOOLS_LIBRARY-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTUITOOLS_LIBRARY_DEBUG
> QT_QTUITOOLS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTUITOOLS_LIBRARY_RELEASE
> QT_QTUITOOLS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTXML_INCLUDE_DIR
> QT_QTXML_INCLUDE_DIR-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTXML_LIBRARY
> QT_QTXML_LIBRARY-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTXML_LIBRARY_DEBUG
> QT_QTXML_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QTXML_LIBRARY_RELEASE
> QT_QTXML_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_QT_INCLUDE_DIR
> QT_QT_INCLUDE_DIR-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_RCC_EXECUTABLE
> QT_RCC_EXECUTABLE-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_UIC3_EXECUTABLE
> QT_UIC3_EXECUTABLE-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_UIC_EXECUTABLE
> QT_UIC_EXECUTABLE-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_X11_ICE_LIBRARY
> QT_X11_ICE_LIBRARY-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_X11_SM_LIBRARY
> QT_X11_SM_LIBRARY-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_XCURSOR_LIBRARY
> QT_XCURSOR_LIBRARY-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_XINERAMA_LIBRARY
> QT_XINERAMA_LIBRARY-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_XI_LIBRARY
> QT_XI_LIBRARY-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_XRANDR_LIBRARY
> QT_XRANDR_LIBRARY-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_XRENDER_LIBRARY
> QT_XRENDER_LIBRARY-ADVANCED:INTERNAL=1
> //Advanced flag for variable: QT_ZLIB_LIBRARY
> QT_ZLIB_LIBRARY-ADVANCED:INTERNAL=1
> //Have symbol Q_WS_MAC
> Q_WS_MAC:INTERNAL=
> //Have symbol Q_WS_WIN
> Q_WS_WIN:INTERNAL=
> //Have symbol Q_WS_X11
> Q_WS_X11:INTERNAL=1
> Qgis-user mailing list
HI,
Can you try to edit the file CMakeCache.txt from:
to:
BINDINGS_GLOBAL_INSTALL:BOOL=FALSE
bye
SL
Salvatore Larosa
GPG: 0xE504BBE2 (FP: D9B2 CA87 81CD 1B91 E24D 3B42 D0F7 FA01 E504 BBE2)
View this message in context: http://www.nabble.com/Configuring-with-ccmake%2C-BINDINGS_GLOBAL_INSTALL-tp18591209p18591992.html
Sent from the qgis-user mailing list archive at Nabble.com.
