[Qgis-user] calculating areas in lon/lat projection
Borys Jurgiel borys at wolf.most.org.pl
Fri Jun 6 01:16:11 PDT 2008
Friday 06 of June 2008 09:01:03 maning sambale napisaƂ(a):
> Using the calculate geometry plugin in lon/lat WGS 84.  What area unit
> does the area column produce?
They should be square degrees, regardless of the user-declared map unit. If
you receive suspiciously high values and they seem to be square meters, it
may be a problem with the reprojection on the fly. Just try to compare with
the area measurement tool.
