[Qgis-user] calculating areas in lon/lat projection
maning sambale
emmanuel.sambale at gmail.com
Mon Jun 9 19:25:00 PDT 2008
borys and carson,
thanks!
maning
On Fri, Jun 6, 2008 at 11:29 PM, Carson Farmer <cfarmer at uvic.ca> wrote:
> Maning,
> The plugin will calculate values based on the input layers coordinate
> system, so if you're input layer is WGS84 then it will calculate areas as
> squared decimal degrees (not very useful as an areal measurement). I
> recommend projecting the layer to a projected coordinate system such using
> the srs management tool, and recomputing your areas this way. Please note:
> This tool ignores all user defined projection information from the current
> QGIS project.
> Oups, I see Borys has already answered your question, well here it is again
> Carson
> maning sambale wrote:
>> Using the calculate geometry plugin in lon/lat WGS 84. What area unit
>> does the area column produce?
| __.-._ |"Ohhh. Great warrior. Wars not make one great." -Yoda |
| '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
| /'.-c |Linux registered user #402901, http://counter.li.org/ |
| | /T |http://esambale.wikispaces.com|
| _)_/LI
